Three way Bosch plugs in engine bay
There are a couple.
I'd like to fix them on this white 88 I have.
One is the cam position sensor (Hall)..
The wires are fine, but the plug has been damaged by someone or something.
I'd like to wire this in:
http://www.ebay.com/itm/BOSCH-3-PIN-...e337a2&vxp=mtr
This seems kinda pricey.
Any other options anyone is aware of?
And what kind of crimping tool is required to repin?
Roger carries those, and yes you can use them to fix the broken connectors, which is the only thing that fails on the hall sensor. The knock sensors however, cannot be fixed with this as they do breakdown.
You can crimp them with a standard crimper of needlenose pliers if you are so inclined and only doing one or two.
