Pneumatic valve technology is coming
Caterpillar used similar technology in their ACERT diesel engines. They did not replace the camshaft but were used as a sort of VTEC aimed more at reducing emissions than gaining performance and only opened the valves, still relied on spring pressure to close them. Many people, myself included, have repurposed the system to hold the intake valves open longer verses opening them sooner as designed with great results. Their system has been known to exceed two million miles.
Actuators won't slam the valves closed nearly as hard as a valve spring will. Valve springs are chosen with enough pressure to control the valves in the worst case scenario and then plus some. With actuators, every aspect of the valve event is nearly infinitely adjustable. It's the future of the performance oriented internal combustion engine. Electric motors are the end game for everything else unfortunately.
True, and the current generation of stuff in production still needs a spring. The actuators just open the valve a little farther or change the timing events a little. What this video is talking about is the next generation of this technology which will get away from needing a spring. That's when things get interesting.
Rennlist Site Sponsor
If the valves don't have to follow the cam, you don't need nearly as much spring pressure slamming the valves shut. I would expect the actuators to be able to exert variable opening/closing forces as needed - valves can be much lighter, reducing forces even more.
Back in 1954 Mercedes re-entered the grand prix competition with the W196, a car with a straight eight laid on it side with power taken out between the fourth and fifth cylinder; essentially a v8 that was cut in half and set end to end. It had desmodremic valve gear where the valves were opened and closed mechanically without the use of springs. The car was a real screamer, winning all the events until a "civilized" version of the car, the 300SLR left the track killing scores of people, Mercedes stopped racing that very minute.
good point. PLUS, its pretty hard to get enough compressed air in a tank to provide any boost at all. a v8 might take 500cfm at 6000rpm. that's a pretty big tank
...and we all complain about Vac leaks in our HVAC or intakes.
Wonder what the symptoms are of a minor leak in the lines leading to the #2 intake valve of the 5th cylinder....or is it the #1 exhaust valve in the 7th cylinder? ....uh..wait..whats the firing order again?.
Agreed, I don't envision anything worthwhile developing with a storage system. But, engine compression braking would be awesome on a track car, particularly an awd model. Diesels can generally generate a minimum of 70% of their rated horsepower in braking force. So a 500 horse engine can generate at least 350 hp in braking force.
