Auto transmission drain plug seal
I need new search mojo - can't find anything.
Anyone have the sizes for the drain plugs on the auto trans pan and torque converter?
Also, is the pan seal replaced as part of the ATF and filter change?
10x14 I think.
And yes to the gasket.
I know Roger sends out two seals, one pan gasket and a filter with his trans kits.
I was looking for the documentation of the updated MB seal but cannot find that either. And I thought I had it saved ![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
I should just send Roger an email to order.
There was a problem in past with gasket splitting round one of bolt holes. Mercedes changed to thicker gasket and Porsche followed several years later.
But I was very careful torqueing pan bolts (used 1/4" torque wrench, tightened bolts in star pattern and in stages up to the specified 8Nm) and gasket fine so far - dry as a bone.
The date on the service kit was post time Porsche changed seal (p/n different in revised gasket), but it still had that old gasket.
Just did a transmission service last month. Call Roger and get the kit from him. I believe it comes with one washer seal for the bolt.
Replace the pan gasket with the filter. You should also get the K1-upgrade spring and replace the kickdown spring while you're in there.
As to the K1 spring, I thought this applied to olders models and/or trans flare but I might be wrong.
The kickdown spring is a good idea.
Oh yea, forgot about the K1 spring kit. I replace those on every trans fluid/filter job I do. Unless of course I've done it previously.
I changed tranny filter a few months back, and the service kit still had the old pan gasket.
Thanks, I had it on the list.
Thanks, I did that last year.
So it's one of those preventive items then. The trans is still unknown territory to me but what the heck, so was the timing belt, cam towers and intake and it runs better than ever. I need to read up on the K1 spring, but is that the only one changed out preventively? There are (many) more springs in the valve body.
It's preventive if you don't have that 2-3 flare (yet). Since you're in there, may as well replace it. It's literally an extra 5-10 minutes and it's only that long because you just need to be careful with the screws. They're on there pretty tight so I had to use a flat head adapter on my socket wrench to break them loose.
http://w123maintenance.blogspot.com/...ement-and.html
Make sure you have a bucket to catch ATF before you swing back that panel. There's quite a bit in there.
