Found a small oil leak
Team Owner
yep its a common issue with the cork gaskets and the low torque used on the fasteners, best to clean the bolts and add a drop of loctite to them, do a few bolts at a time.
NOTE its also wise to swap out the OPG for the new silicone version,
I suggest a drop of blue loctite on the bolts when fitting this new gasket
