bosch water pump 97127
Basic Sponsor
Bosch as far as I know does not make a 928 water pump so it is made by a third party possibly.
It is certainly a very old design as it uses a metal impeller with no additional bushing to keep the impeller on the shaft. Unless someone has masses of "in use" backup I would not use it on any of my cars. Far better to use a well know manufacturer with a track record and a plastic impeller.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
That listing is very similar in a few respects to one posted here very recently ... with a metal impeller.
Be worried about a metal impeller, but also be worried about what you can't see .. the bearing pack.
Give Roger a call and get a known pump with backup, at a fair price.
Basic Sponsor
Porsche went to the plastic impeller. Laso, when they were still supplying a metal impeller, added the extra bush as an interim fix prior to going to the plastic impeller.
Both Porsche and Laso are fitted with the plastic impeller. Have been for some time now.
Hence my comment about the old design of the "Bosch" pump - at least two design iterations behind current manufacture.
any other issues with them other than that?i can peen ,pin or tack the impeller so it will never come off.can't justify spending close to five hundred on a laso.my bb chevy marine race pumps don't even cost that.lol.
Valve damage cost out weighs the cost of a good pump. Risk it if you want, but it's a big big risk. I would go insane every time I drove with a questionable pump.
Basic Sponsor
If money is the issue you can buy a nice rebuilt pump for about $100 and probably the same high risk factor. Pinning the impeller will certainly reduce the odds of failure.
roger,can you get me the parts to rebuild mine?can't be anything to it.press shaft out new bearing and seal.is there any way to tell if it is the original?it has a black plastic impeller and there is no sealant on the gasket.
Basic Sponsor
I do not have the parts to rebuild the pump - sorry.
If it helps I can sell you a new rebuilt pump for $85 as long as you accept all responsibility for it with no comebacks to me or my company.
Or hold the person/shop who installs it responsible either. I've told plenty of people that they can use those rebuilt pumps, but if it fails the day after it's installed, they will be paying the labor to replace it twice.
