928 Forum 1978-1995
Sponsored by: 928 Specialists
I bought my first Porsche 928 - Nightmare!
Old 03-04-2014 | 10:46 AM
  #61
racingsnake's Avatar
racingsnake
2nd Gear
Originally Posted by BehindTheWall
Hi. With registration is not that bad. They will charge me 0.1% from 200e every day when the car is unregistered, so 12c per day . On Monday I will have car checked by mechanic and we will see. Maybe it's not so bad as it looks.
Never seen a thread so full of woe.
So, what is the latest from the mechanic? Any news? If you need some "off Rennlist" help and want to do the cry for help more privately, please join up at 928.org. We don't bite, have all been where you are now to an extent and sarcasm and smart *** comments are rare.
Old 03-04-2014 | 11:38 AM
  #62
BehindTheWall's Avatar
BehindTheWall
Yes, you're right. Some Postings were unnecessary.
So the news are: Broken radiator cause the problem with oil mixing with coolant. So right now I'm looking for good used radiator.
Old 03-04-2014 | 12:00 PM
  #63
UKKid35's Avatar
UKKid35
That's great news, seems you've come off really lightly!
Old 03-04-2014 | 12:02 PM
  #64
racingsnake
2nd Gear
Brilliant news. Any other questions you or the mechanic have, post them up.
Old 03-04-2014 | 12:38 PM
  #65
BehindTheWall
Has anyone tried to fit s4 radiator + s4 small oil radiator in pre s4 cars?
Old 03-04-2014 | 12:58 PM
  #66
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Since a pre-S4 radiator fits fine in a post-S4 928, the opposite should work, other than the lack of those plastic L-shaped tabs that hold the upper fan shroud. I'd guess there's a simple fix for that.
Old 03-04-2014 | 01:37 PM
  #67
comicbook8's Avatar
comicbook8
great stuff !
now dont forget to join the porsche club ireland !!!!!!!!!!!
Old 03-04-2014 | 02:29 PM
  #68
F451's Avatar
F451
Any idea of the condition of the engine? You mentioned vibrations before it puked and that it wouldn't (or wasn't) accelerating.
Old 03-04-2014 | 03:24 PM
  #69
mickster's Avatar
mickster
Spend on a new one if you can afford it. They will last 10-20 years if treated right.
Old 03-04-2014 | 04:09 PM
  #70
James Bailey's Avatar
James Bailey
You can run it without an oil cooler if you loop the lines.....would be good to KNOW the engine runs O K ...You can get replacement plastic tanks and seals with or without holes for the heat exchanger so your old radiator could be put back together !! Locating a heat exchanger is hard..but as you mentioned an external air to oil could be fitted.
Old 03-04-2014 | 04:18 PM
  #71
wg928's Avatar
wg928
fonetico said:- "I confess that I'm as guilty as anyone when it comes to posting flippant and frivolous comments that are of no help to anyone. Usually, as in this case, they follow a liquid lunch and for this I apologise.
However, there is a good and serious intention behind them."
I just fell outta my chair rolled over laughing at this intro (too funnaye for words)
Err; anyway,
Seems like there's likely more than what meets the eye....; this car when sorted will give you many moments of joy, lots of folk here have taken beatings but keep going back for the joy.
Give it a good try.
Best.
Old 03-04-2014 | 04:32 PM
  #72
The Fixer's Avatar
The Fixer
[QUOTE=James Bailey;11185601]You can run it without an oil cooler if you loop the lines.....
That shouldn't be necessary.
[QUOTE=wg928;11185622]"I confess that I'm as guilty as anyone when it comes to posting flippant and frivolous comments that are of no help to anyone. Usually, as in this case, they follow a liquid lunch and for this I apologise.
My sides are splitting.
Old 03-04-2014 | 04:40 PM
  #73
ricster's Avatar
ricster
I would put a radiator in it, then dump it. If you dont have a huge bank roll 928's can bankrupt you. Get a 911 a much better reliabilty and better on resale over the long haul. Just my 2 cents.
  #74
James Bailey
[QUOTE=The Fixer;11185665]
.....[/B]
BEFORE he buys a $1,500 radiator it would be good to KNOW the engine is O K ....the 1980-1984 USA cars never ran the heat exchangers for the engine oil so unless you are really using the 300 HP a lot the car can live quite well without it.
Old 03-04-2014 | 04:43 PM
  #75
Leon Speed's Avatar
Leon Speed
Lot of good that will do on a 928 forum
Quick Reply: I bought my first Porsche 928 - Nightmare!
