heads up for anyone needing a water pump
Cast iron impeller, and not clear to me what year it is for?? The listed part# is just the casting number, it's not a '87-95 and doesn't look like it is machined correctly for the earlier tensioner setup?
That casting no crosses to a 180-2150, which is used for a rebuilt GMB pump and shows it fits a number of years. Why no part number on the pump? Makes me nervous.
Looks identical to the pump I just pulled out of my 87. That pump was from 1999.
Johny, I think it is kind of a moot question since this thread is 5 and a half years old. Or, am I missing something about your post?
Model is important, as the 32V unit (at least) is different in its alignment, apart from the tensioner pivot post. In the pic , early pump on right, note that the pulley is further from the mounting face than that on the later pump. Its not an illusion.
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
Chronic Tool Dropper
There's an extended discussion, now historical, about the impeller material (plastic is better) and the quality of the bearing cartridge used. Choosing the lowest-cost discount knock-off pump risks the metal impeller working it's way to the rear and re-machining the cavity in the block. Getting the wrong pump can be a pretty expensive choice.
