928 headers, part deux
#31
Which is why such products are so hard to protect (and rightly so) under our intellectual property rights laws. Those laws are designed to protect innovation; they are not designed to bar potential competitors from applying generally understood principals to enter a market just because you applied those principals first.
Note: I'm not an attorney nor do I play one on TV. I have had several clients for whom intellectual property rights were a big deal, so I've a fairly good understanding of the area. ("Fairly good understanding" = "enough to be dangerous".)
#32
I just now looked, ebay listing is up $399 plus $45 shipping.
http://www.ebay.com/itm/OBX-Steel-Ex...-/111269538875
I hope you can find a way to not let them get away with it.
Small bump in the defendants getting the ebay listings down, there were several more MSDS part numbers involved in this IPR case . There may be penalties assessed for each day this is not cured. The legal team is also busy notifying distributors of these part numbers.
Marty
#33
David,
this was a detailed IPR case, and extremely interesting on how it was (so to speak) assembled. You are off in left field with your analogy, but since the defendant did not stipulate "Off of public record" I can provide whomever I want with copies of the case. Makes for good reading !
Marty
Marty
#34
"Interesting" as this is appears to be... one has to ask if ORIGINAL header companies like Hedman & Doug's ever sued the domestic 'upstarts' like Hooker, Blackjack & MSDS or the European ones like Borla, Billy Boat or Bursch? I know Hedman is still in business... not sure about Doug Thorley.
I always preferred the R&D and quality control of the Hooker designs -even if they were only available in mild steel.
#35
David,
Marty
Marty
#36
handshake later we were building his product , approx. 250 sets a month
alongside our MSDS headers in our plant. When Bette passed on, her
company was sold off . Doug later sold to Patriot Headers (Pertronix).The
original Tri-y design Chevy, Ford, Mopar header was Doug's
innovation.
but the IPR may have went with Bette's company. I don't know how
long that battled in court !
Marty
#37
Correct if they were current - according to the Maltese Falcon they were designed and tooled prior to 1985. So non-recurring has long been recovered and as they require no further design input costs should be driven down. Parts are now just a "cash cow" and it should have been easy to compete with an offshore supplier - just protecting your large profit margin does not work in the modern World.
#38
Just bought a set £500 uk money inc shipping which £160 was shipping cost took three days from states . Had to turn flanges down to get a good fitt only got to make X pipe now for fitment.
#39
OBX headers
[QUOTE=potdog;15281013]Just bought a set £500 uk money inc shipping which £160 was shipping cost took three days from states . Had to turn flanges down to get a good fitt only got to make X pipe now
Hi how did fitting the headers go? Did you use the original Porsche O ring metal gaskets on the manifold or the ones supplied with the headers?
Cheers
Nige
Cheers
Nige
#40
Ok since this thread was brought back from the dead I will play as well ; )
Whats the status of 16v header availability? I have the original MSDS gen 1's with jet hot coating. They still perform very well, some surgface rust but we are talking original from around 35 years ago, car came with the original brochure.
My problem is not being able to service the clutch or lower the bellhousing without loosening this set. Would prefer an updated design if possible.
#41
Administrator - "Tyson"
https://www.msdsinc.com/contact.html
#43
I see it as a minor inconvenience. I had to drop the bell-housing on my 79 this past weekend. It didn't take that long nor was it all that difficult to loosen the nuts on the passenger side header & the housing fell right off (literally, I had already removed the starter, slave cylinder and all the bolts).
