dash lights 82 928s euro
my console lights work but dash lights stopped working, dimmer switch works for console, i am going to take the pod out for some repairs, can i hook up 12 volt power to the flex foil,printed circuit board to check for power if bulbs are ok, do they have leds that would replace dash lights
where would you hook up the ground
Try disconnecting your dimmer switch first then check all your fuses. I just replaced all the bulbs with LED's including the 3 base reflectors with LED's embedded in the prisms.
At last I have light the cluster.
I was afraid of the " Tokyo by night" experience but they are no brighter than my Jetta. I went for the blue LED's sold by Peter in Thailand. They are the replacement prism's.
The rest of the bulbs are a mix of LED's and standards. High beam is a blue LED and turn is a green LED. The jury is out on the LED's I put in the *****. The head light and the defrost is a bit bright.
we had pulled all fuses and cleaned them up along with relays and grounds, we had a problem with the ignition not working 75% of the time, at least it works more than 90% of the time now, will do dimmer switch and see what happens next
