928 Forum 1978-1995
Sponsored by: 928 Specialists
supercharger interest
Old 01-30-2014, 12:38 PM
dpower$
dpower$'s Avatar
Default supercharger interest
Wanting to add a supercharger to my early '86. I currently have PorKen's latest chipset will theses be OK? I also want to know what a provent is, if and why I need it and what will be a reasonable cost to buy one and have it installed? Thanks.
It will be a centrifugal type run at relative low boost and will not be using a inter-cooler.
Old 01-30-2014, 12:45 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,076 Likes on 1,185 Posts
You can read all about the Murf928 Supercharger kit for the 85/86 cars here.
This thread documented the first Stage 3 85/86 car and the Rennlist based gathering that followed the build to deliver the car to Shane:
https://rennlist.com/forums/928-foru...s-new-car.html
Website: http://www.murf928.com/
Contact: info@murf928.com
Old 01-30-2014, 12:51 PM
davek9
davek9's Avatar
also you will need to burn custom chips or use whats supplied w/ a kit.
Ken's chips will have way too much spark advance for a blower, they are designed for optimal performance w/o add-on's.
edit: simply put a Provent is a device to prevent and then drain off the oil that is ingested into the intake from PVC and blow-by (this will be greatly enhanced w/ a SC).
Dave K
Old 01-30-2014, 01:00 PM
SeanR
SeanR's Avatar
This thread documented the first Stage 3 85/86 car and the Rennlist bases gathering that followed the build to deliver the car to Shane:
The above has all the information and you will need to SC your car.
Old 01-30-2014, 02:09 PM
Tim Murphy
Tim Murphy's Avatar
Hi there dpower$
The provent is not required on the Murf928 kits since there is not excessive oil blowby from the breather system with our supercharger kits.
The Murf928 Stage One kits are basically the same as the Stage 3 but without an intercooler and lower boost.
Are you asking about having the supercharger kit installed, or just the provent? Where are you located?
Old 01-30-2014, 02:24 PM
James Bailey
James Bailey's Avatar
Kansas City based on several of his posts of craigslist items there. He needs it installed as he used a mechanic to change a window motor.....not a hands on do it yourselfer.
Old 01-30-2014, 02:31 PM
jeff spahn
jeff spahn's Avatar
Ooohhh. Not hands on and wants to supercharge a 25+ year old car. Ballsy.
Old 01-30-2014, 02:59 PM
hacker-pschorr
The Murf928 Supercharger setup is plug-n-play, tested and proven on about 90 - 928's worldwide.
Many (dare I say most) have been sold to people who are not "hands on" who worked through the install themselves or had their local shop do the install for them.
Old 01-30-2014, 03:16 PM
auzivision
auzivision's Avatar
I wasn't a hands on Porsche guy when I decided to install my Murph kit and didn't have a problem. I guess it's all in them genes
Old 01-30-2014, 03:25 PM
Avar928
Avar928's Avatar
I believe it's strongly recommended that your car is running at peak shape before you supercharge.
Not sure if that entails an engine rebuild but at least refreshing everything short of pulling the motor.
Old 01-30-2014, 03:29 PM
AO
Supercharged
AO's Avatar
YES! 928% correct!
Not a full rebuild, but if there are any deferred items, the addition of a SCer will point them out soon enough.
Old 01-30-2014, 03:57 PM
jeff spahn
jeff spahn's Avatar
THIS, is what my comment was all about.
Old 01-30-2014, 08:23 PM
dpower$
dpower$'s Avatar
The kit I am referring to is the kit that CosmoKramer sold here to Temekun last year. Seems that many are familiar with it. I contacted him and am in the process of figuring out what it will need. My car is currently in the shop having every PorKen mod added. Has Ott x-pipe and AA chips currently. My mechanic states that it is sound for boost, the only thing it needs is for me to run the S**T out of it. Car sits a lot. Car was a gift from my wife 11 years ago for my birthday. I lost her to pancreatic cancer a month ago, decided to start driving it kind of for her. I have a good mechanic I trust who allows me to bring outside parts. I do not even change the oil. In 11 years I have put about 7K miles on the car mostly OCIC & 928's on the Autobahn type stuff
Old 01-30-2014, 09:27 PM
Avar928
Avar928's Avatar
Sorry to hear about your wife.
Make sure you run a checklist on the condition of the car before boosting it. Cover everything, probably have it dynoed so you have a baseline of where you're at and that you're getting the most out of the power adders.
Old 01-30-2014, 09:40 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I'm familiar with Kosmo's kit. It's a well sorted out one, I think he kept the Provent. He worked hard to get everything figured out. Besides the Provent is there anything else missing?
Quick Reply: supercharger interest
