Awesome and/or crazy turbo project. You pick.
#61
Administrator - "Tyson"
Hacker I totally agree with your comments. I've built many different high performance and/or turbo cars in my past and have found poor tuning at the root of most failures. People are somewhat routinely making 500hp to the wheels from 4g63 engines now with rod bolts, head bolts, and a head gasket. I'm trying to be realistic and keep my goals low, but I think my setup can easily eclipse 500 to the wheels on an inertia dyno. In fact, I think I can pass 450rwhp on the U.S. motor with the U.S. cams. Again, I'm not banking on that yet. The turbo is good for about 750 at the crank...but I won't take it near that far.
My stock US 16V passed 400rwhp with a 1:1 ratio of exhaust back-pressure to the intake manifold. That was not helping things.....
That was also with a very crude "tune" using an FMU to crank up fuel pressure.
That project has been on hold due to a fix-er-upper house we purchased and a few other factors like EuroS cams I purchased that fell off the face of the earth that kind of pulls the rug out from under you.
Todd has the designs on the table for a new IC for my car that will be using a core that is just over 500 cubic inches.
Go big or go home.....
#63
Hell yeah Sean come on over, perhaps when it's not so damn cold! I'll have the Arnold Palmers and Tuaca lol. Hacker was your setup on the stock intake manifold, throttle body, etc.? What size turbo? Thanks, Evan
#64
Wow dude, I've heard you jawing about this kind of stuff off and on for a year or so now, but never seen any of it. Where is your shop, up in Sheridan? I vote we have our mid month beer night up at Evan's!
#65
Yeah the garage is in Sheridan. I'm in Noblesville. It would be better in warm weather, but I have a few other projects up there too that are pretty neat.
#66
Exhaust is 85/86 manifolds with a 3" straight through exhaust.
#34 on the Murf928 site (even-though it's technically the second car we bolted the parts to for prototyping):
http://www.murf928.com/customercars.htm
My car now has all EuroS intake / TB etc... with the ECU and ignition from a EuroS so I can SharkTune it. That's pretty much where it sits now. Needs to be tuned and a few things tweaked, but that's on hold for a bit as I finish other projects.
#35 on the Murf928 site belongs to Rennlister Jean-Louis - that is a stock (except for exhaust) EuroS 16V engine with 10.4:1 compression putting down just shy of 400rwhp in a full race car (not just DE's).
If anyone has proven the durability of a boosted 928, it's him.
The oiling system has been modified for track use on JL's car.
#69
Thanks for the info. I plan on modifying my oil system as well. I wonder what the stock valve springs can take for rpm safely. I'm betting 6800 or a little more.
#70
I've done a mid mount turbo on a local fellow's car.
Using MSII V3.57.
4.5L
Cams are base circle cut, but US 82 cams.
Intake is modified to have the throttle body on the front of the intake, with the bottom capped off. US runners, and plenum.
Low boost 9 PSI, we have run up to 19 PSI (where I set the boost cut off in case of wastegate problem). I tuned it up to 21PSI. But need to do a little more work to be able to get the IC to stay connected to the throttlebody over 17 PSI. Full boost by 3k RPM. Comes on smooth and steady. Not much if any lag. Car is a bloody missile...... I haven't put it on the dyno just yet. But I can tell you on high boost, it is making well over 400......
Using MSII V3.57.
4.5L
#71
Does Windex work as an air cooler? IJS... you want to keep the glass clean right?
#72
Lizard I was wondering when you would chime in too. I have your shifter BTW. If the car you're talking about above was tuned up to 21 psi I'm curious how the knock looked. I'm assuming it has at least one sensor if not both up top. Was it gas or corn powered? What size turbo?
Hacker sorry to hear about your setbacks. One of my buddies decided to remove the sprocket from one of my euro s cams in a way I'd rather not remember. It's at a shop in Florida being looked at now to repair the keyway.
To answer a previous post of yours, I think the total combined runner length is somewhere near 6" last I measured. Not sure if that includes the port or not. They have no taper and are the same diameter as the 85 euro s heads. Really the big reason I run the extensions in the plenum is because those trumpets were cheap and readily available, and I thought since the beginning the air would enter the trumpets more uniformly elevated from the floor a bit. I also am guessing the air shooting in the front from the throttle body might distribute better going around the trumpets partially vs. having it all shoot across the top of the first one or two.
I love the crap about Windex! We've made the same jokes here. When I run water/methanol we always get blue windshield washer fluid. Maybe I can do that haha. As a side note, I've run the water/methanol a few times before and I can't believe how good it works. You can get away with murder on how much boost or timing can be run. Another, perhaps better, side benefit...I've pulled the head off a couple motors that had been spraying the stuff somewhat regularly. They always look brand new inside because the carbon gets steamed off. That means better ring seal etc.
Keep the information coming people I love it, and thanks for the comments.
#74
I plan to drill the ant farm for better oil distribution so air doesn't favor the #2 main based on the information I found here: http://translate.google.fi/translate...D13%26t%3D7951
Google translate is necessary to open. Thanks again Hans for the link.
#75
There were no detectable knock events on 94 octane fuel.
No corn fuel up here. Even if we wanted to run it.
So long as the intake temps are under control and the timing is pulled properly the level of boost isn't a huge issue, especially at higher RPMs with a stock US intake manifold....
As to the turbo, it's a comp unit with the race impeller.
