Know where this goes?
I just finished my Oil Pan Gasket, Motor Mounts & Steering Rack replacement. When I was cleaning up the area, I found this washer. Does anybody know where it goes?
The Exhaust manifold and the A-arm was not removed on this go around.
Thanks for the replies, I will see if I can see if anything is missing. Don't want to start removing things again.
Shameful Thread Killer
Maybe if a bottom MM washer, and he has aftermarket MM, this washer would be left over. Meaning there should be two leftover depending on which aftermarket MM was installed.
It isn't bottom MM washer. They're much larger.
It's either the top MM washer, or it's the washer for the bolt which holds up the bottom protection plate on the wheel side of the rack input.
