Growling sound under console, what could it be?
Team Owner
this looks pretty bad,
I would be releasing the clamp and checking crank end play first,
to be showing this much of the splines means the plate was really pushed forward.
Also i would consider replacing all of the bolts that hold the pinch clamp front and rear,
the flex plate to flywheel,
and hub to the plate ,
given the corrosion all of the bolts are suspect.
NOTE make sure to replace the rear pinch bolt I will bet its loose
I have seen that on another local car. It was a case of bad bearings allowing the shaft lateral play.
Car is just fine after a new flex plate and TT bearings. Still running the streets several years later.
I think it looks worse than it is. Although, dropping the TT in the driveway is one of those not so fun jobs.
You can call me Otis
The flex plate was in such a bind forward I had to unbolt it to relieve pressure so the clamp would slide rearward, a 1/3 section of the flex plate fell out, but there is not eneough clearance between the front end of the splined shaft and the flywheel to remove the rest of it. Once the force was removed from the flywheel I did a simple check of flywheel play with a small prybar, literally maybe a frogs hair of movement. but here is the best part, the TT splined shaft had very sloppy lateral movement, and the front TT bearing is only 17 inches from the front of the TT.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Needless to say, the TT is coming out for a rebuild. I will to use the information here to guide me though this, so not too worried about it.
[URL="[ame]http://i1321.photobucket.com/albums/u550/otr18wheeler/flex%20plate/100_2458_zps3ccd6ddc.mp4]
"][URL=http://i1321.photobucket.com/albums/u550/otr18wheeler/flex%20plate/100_2458_zps3ccd6ddc.mp4][IMG]http://i1321.photobucket.com/albums/u550/otr18wheeler/flex%20plate/th_100_2458_zps3ccd6ddc.jpg[/IM[/ame]
[IMG]
[/IMG]
![](http://i1321.photobucket.com/albums/u550/otr18wheeler/flex%20plate/th_100_2458_zps3ccd6ddc.jpg)
[IMG]
![](http://i1321.photobucket.com/albums/u550/otr18wheeler/flex%20plate/100_2448_zps1aa872da.jpg)
Just some encouragement for you. I'm finishing TT rebuild right now on my wife's '85 AT. Follow the advice on here and it isn't that bad, except for the crawling around on the ground part.
I used Bill Ball's procedure (there are a few threads on RL, actually) to do it without dropping the trans. It worked fine, my biggest problem was frozen bolts (and freezing temps that keep me out of the garage).
Good luck!
Good luck!
thanks otisp, I would be lost here if not for all of the 928 community, especially Bill Ball and his instructional input.
At least it has warmed up here, and a vinyl tarp on the garage floor makes it easier to scoot around underneath.
Get a constantine clamp since you are taking the TT out. Spend $1500 more and get a super nice brand new shaft with super bearings and a shiny pre assembled TT. Makes the job seem that much nicer.
928 Engine Re-Re-Rebuild Specialist
Here's the write-up by Bill Ball that I followed for removing the tube. You do need a about a 50 ft extension for your 3/4 ratchet, but other than that not too bad.
http://www.billsworkshop.com/P928S4/seal/seal.htm
You can get the bearings easily at a bearing shop (pretty cheap), then get the old ones pressed out of the holders and the new ones pressed in (unless you have a press). Cost me 10 bucks. Just don't forget the inserts from the old bearings.
I got my bearings and new inserts from Jager http://www.jageng.com/garage9/
I followed their procedure for drifting the bearings out of the tube, easy. I also found this - MrMerlin's suggestion is the same.
https://rennlist.com/forums/928-foru...some-more.html
Good luck! I did it alone, so it can't be that bad, I would recommend keeping some Bushmills or Jameson's on hand, though.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
