How bad might tap water be in radiator vs distilled?
#32
Chronic Tool Dropper
I hear there are trained moles available to count the atoms.
#33
After seeing what comes out of our humidifier each time I clean it, I'm very reluctant to ever put our tap water in one of our vehicles.
Granted, a lot of water passes through that humidifier (and is boiled off), but still...
#34
Archive Gatekeeper
I see what you did there.
#38
Ed, that just de-humidified the water in the tray. You need one that dehumidifies the air and puts the water back in the tray. Try reversing the plug...
#39
#40
Use the distilled water. After I took off the water bridge and water pump on my 82, there was a lot of calcium buildup. Especially bad was the temp sensors. I cleaned them off and they work like new again with much better temp accuracy on the gauge.
