928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil pressure question
Old Nov 14, 2013 | 08:22 PM
Jetdriver69's Avatar
Jetdriver69
Default Oil pressure question
Just installed new oil sender on fresh M28/16 4.5L rebuild. Everything is working as adverstised with no leaks on first runup, but the oil pressure goes from 0 to 5 bar instantly after the engine fires
Shouldn't the idle range be around 3 or so and work itself up to 5 with increased rpm? Could it be a bad sender or wiring issue? We are using Valvoline Racing oil 30 wt organic for the run in.
We are going to hook up an external oil pressure gauge to check for sure tomorrow. Thanks.
Old Nov 14, 2013 | 08:25 PM
Bilal928S4's Avatar
Bilal928S4
It seems normal operation. On my cars the oil pressure gauge is pegged at 5 on start up and until the car and oil reaches operating temp, then it comes down. After that it will increase or decrease with engine rpms.
Old Nov 14, 2013 | 08:28 PM
The Forgotten On's Avatar
The Forgotten On
Just as Bilal said it is perfectly normal. It will go down as the engine oil warms up. Nothing to worry about, if it was at 3 or lower at start up then I would be worried.
Old Nov 14, 2013 | 08:31 PM
outbackgeorgia's Avatar
outbackgeorgia
Unless the sender is wired backwards, then it will stay at 5 bar.
Old Nov 14, 2013 | 08:35 PM
Jetdriver69
Thanks, will check for backward wiring tomorrow before hooking up external gauge.
Old Nov 14, 2013 | 08:53 PM
Tony's Avatar
Tony
You can always empty the oil and start it and see if the opposite happens!
Old Nov 14, 2013 | 08:58 PM
James Bailey's Avatar
James Bailey
It takes about 15 minutes of driving to get the oil really up to temp.....
Old Nov 14, 2013 | 09:00 PM
Bertrand Daoust's Avatar
Bertrand Daoust
Like Bilal said.
Should go up to 5 at start up when cold. Idle or not.
Then goes down to about 3 at idle when it reaches operating temperature.
And should go to 5 again as soon as it is over about 1500 rpm.
Old Nov 14, 2013 | 09:05 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
NOTE if the sender is miswired.
THEN when the key is turned onto the run position,
the gauge will peg at 5 bar without the engine running
Old Nov 14, 2013 | 09:21 PM
928 at last's Avatar
928 at last
What Bilal and Mrmerlin said.
If it pegs with the key on and not running, could be a bad or crossed connection. Happened to mine when the insulation decided to call it a day. Easy fix.
Old Nov 14, 2013 | 10:45 PM
Tony's Avatar
Tony
Im still trying to trace mine. Its PITA!! Its never worked
Old Nov 14, 2013 | 11:49 PM
928 at last
Default Sometimes the sender
Sometimes the sender itself gives up the ghost...have you tried replacing just that bit? (A little fussy to get to, but not a total PITA type fix...)
