928 Forum 1978-1995
Sponsored by: 928 Specialists
Head bolts for 32V car
Old 11-11-2013, 10:39 PM
docmirror
Shameful Thread Killer
docmirror's Avatar
Default Head bolts for 32V car
I have a set of head bolts for S4 and GTS. New, never torqued.
I'm thinking $175-ish for the set. PM or post if you want them. This is about cost for the set.
Also have a S4/GT/GTS head gasket if you need it.
Old 11-11-2013, 10:54 PM
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
If it's a whole set of 20 and brand new, consider them sold.
Old 11-12-2013, 12:16 AM
docmirror
docmirror's Avatar
Sorry, I should have been more accurate. It is a set for a head. One head, 10 bolts, brand new. If that's too high let me know. I paid ~ $20 per bolt.
Old 11-12-2013, 12:27 AM
namasgt
namasgt's Avatar
Really? I think I bought mine from Roger for about $13-$15 each. Have prices gone up?
Old 11-12-2013, 02:21 AM
GregBBRD
Former Sponsor
GregBBRD's Avatar
Yes. Last year. Retail almost doubled.
They must be running low on them.....
Old 11-12-2013, 02:58 AM
docmirror
docmirror's Avatar
OK, if I have this right(I think), there are 9 bolts that are 150mm, and they were $20ea, and one that is 133mm and it was $19. If someone needs the set, I will let it go for $150. Fits 87-91 S4/GT.
Old 11-12-2013, 11:15 PM
namasgt
namasgt's Avatar
Doc after 88 the head bolts got 20mm longer due to the 20mm thicker bosses on the heads. Not sure whats the correct length for the 87-88 cars with R1 heads but for 89-95 (with R2, R3, R...heads) all the head bolts are 20 mm longer.
Old 11-12-2013, 11:59 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,719 Likes on 1,319 Posts
Just for the sake of OCD- Doc's set should be good for an R1 head, used up through early 1988 (engine # 81K 00120, (5-speed), or 81K 05238 (auto)
So R1 head bolts are 180 (928 101 231 01) and 130 mm (928 101 233 01), and R2-R5 head bolts are 149 (928 101 233 02) and 199 mm (928 101 231 03)
Interestingly the R1 head bolt numbers are listed on the bottom of the M28.43/44/45/46 page in the '85 PET- were they spec'd as replacements or something?
Old 11-13-2013, 01:17 PM
worf928
worf928's Avatar
Received 1,624 Likes on 1,061 Posts
Is there something extra-special about OE head bolts other than the odd lengths (e.g. 149, 199...) Are they otherwise just M12x1.5 8.8 bolts?
Old 11-13-2013, 01:29 PM
worf928
worf928's Avatar
Never mind. I get it. 1.5 pitch bolts longer than 100mm are rather tough to find...
Old 11-13-2013, 01:31 PM
Rob Edwards
Archive Gatekeeper
Pretty sure they're Grade 10.9, for whatever that's worth. M12 x 1.5 mm (fine pitch). McMaster has no M12 fine pitch in 10.9, and bolt depot only goes up to 100mm
http://www.boltdepot.com/Metric_hex_...m_x_1.5mm.aspx
Not your average ACE hardware bolts!
17prospective buyer
17prospective buyer's Avatar
Quality of the (stainless?) steel is important for torque to yield fasteners and i think OEM is just the best way to go for peace of mind. After all, how often do you do head jobs. I think ARP makes stud kits for 928 motors, that way you can just use nuts. Although you'd sacrifice serviceability since you can't remove heads with motor in situ. Need to remove motor.
Old 11-13-2013, 01:37 PM
docmirror
docmirror's Avatar
Now I'm gonna have to go measure them. I'll get back and let you know what I find.
Old 11-13-2013, 01:54 PM
worf928
worf928's Avatar
Don't bother unless your insatiably curious. The issue is just that M12x1.5 bolts in lengths over 100mm are not obviously easily available. I am skeptical that the 149mm and 199mm long bolts couldn't be substituted with 150 and 200mm bolts (if you could find any.)
Old 11-13-2013, 01:55 PM
ROG100
Basic Sponsor
ROG100's Avatar
OK here is what we supplied to Doc ----
9 x 928 101 231 03 - M12-1.5 x 199 - List $28.53 each
1 x 928 101 233 02 - M12-1.5 x 149 - List $19.63
Quick Reply: Head bolts for 32V car
