Vacuum readings
Vacuum readings
I have replaced most of the vacuum lines in the engine bay (except the one to the tranny and the one to the EZF.
I have used generic rubber lines that I had left from the vacuum line job on my Jeep.
It did improve idling and the tranny shifts more smooth.
Th mightyvac measured around 14 at the EZF hose. Is that within norm?
Thanks in advance for your insight.
Chronic Tool Dropper
Vacuum leaks, ignition timing, cam timing, leaky intake valves. Pretty much in that order.
Your "vacuum line to the EZF" comment hints at your car's pre-S4 vintage, so your ignition timing is adjustable and has vacuum advance/retard? Good idea to verify that the vacuum lines are connected correctly for the vacuum advance unit if you have one.
And....
Add your car's year and other details like the auto trans to your signature line. You get to do that manually in each post until you decide that the forum is worth the few dollars for regular membership. Most folks, especially new owners, can gather enough benefit in the first few minutes of accessing the forum to justify membership costs.
And....
And....
And....
I doubt that the ignition timing on my car is adjustable, as the distributors are mounted on the camshaft gear covers.
There is a noticeable difference in how the brake pedal feels with engine on and off, so the booster seems to be working, but I`ll check the vacuum tubes there, thanks for the heads up.
