928S Cayman rims question
OK now put this wheel on the right side rear and lets see how it fits
you may need to pull the rear fenders out some along the edges with two hands wearing thick leather gloves,
gently pull along the edge and the fender will move outwards a few MMs use both hands
That said FJ also brings up a good point the whole rear cross member may be pushed to one side
That's what I mean with the S4 chassis. The 86 has the complete running gear (brakes, suspension, exhaust line, chassis of the S4 but with the original body.
Only made one year.
Think that's the issue
The older style wheel hub.disc brake probably won't fit?
Only made one year.
The Michelin tires are rather thick on the outside. I could gain maybe 1 cm when the tire would be the same widh than the rim.
What brand & type of tires do you guys use?
Maybe some pics?
Maybe some pics?
Stefx, given they don't quite fit, you'll need to roll the wheel arch lip flat (like the GT had), or change to thinner rubber. Porken had the original 265 wide on his S4 with Cayman wheels, but then replaced them with 255 DWS on the rear
https://rennlist.com/forums/10032562-post40.html
https://rennlist.com/forums/10035397-post45.html
