S4/GT Swapped 8 point / 2 button to 12 point / 3 button heated seats wiring question
I have looked at the other seat threads for this question and did not see what I am looking for:
I swapped my 8 point to 12 point (found a set of 12 point heated) and had Robert Budd redo them in Linen (they look great) and my car was ready for the wiring less the heated 2 prog connector (like the one that is for the seatbelt sensor on the driver's side).
Question is:
Is this a simple ground and 12 V connection and does anyone know which wire is which? I also want to fuse this correctly if anyone knows.
It looks simple, but then again that is usually the death nail...
Thank you
Emerald
Question is:
Thank you
Emerald
Question is:
Thank you
Emerald
Question is:
Thank you
Emerald
I've connected my 12-way seats up to power on the bench to move them around when I had them out for cleaning etc., and it was just two pins needed. I can't remember which wires it is - look for red and brown ones, it wasn't hard to spot IIRC.
Also be careful not to crush the connector with the seat rail when putting the seat down
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Hope you did not do that. Pricey litle connectors. Does itmatter which is ground and 12V? And do you know what fuse level? I will run wires from the fuse panel for each side.
