has any one taken off valve covers without taking off intake manifold?
So when I remove the valve covers I should also replace the camshaft seals? It seems like a strange ideo but I want to replace the valves overs then do the intake repaint and testing.
I am going to curse myself now. I have no oil leaks. Then again, I have replaced pretty much every gasket on the car in the last 2-3 years, some twice.
Chronic Tool Dropper
My feeling generally is that these seals are fine until they leak. Look at them again when you do a scheduled timing belt replace. At that time, popping the cam covers off for a seal replacement won't impact your whole project scheule by more than an hour. While adding a 12+ hour TB project will make your cam cover project 6x as fun.
Those are the hockey puck seals right?
Only if they're leaking. Otherwise leave them alone. For the front, driver side you may be able to replace without disassembling the front. The passenger side necessitates you disassemble pretty much everything on the front of the car just to get that cam gear plate off to get to it. Not sure how difficult the rears are.
If you remove the valve covers you have to replace the spark plug cylinder and valve cover gaskets.
