928 Forum 1978-1995
Sponsored by: 928 Specialists
Interesting radiator failure mode - Sharktoberfest shakedown
Old 10-23-2013 | 10:43 PM
  #31
GregBBRD's Avatar
GregBBRD
Former Vendor
Originally Posted by 69gaugeman
Well, I am still not convinced. I thought about the acceleration in the water pump too, but two factors limit this theory. One is that it is an impeller style pump with quite a bit of clearance. Like a turbo charger it is inefficient at low revs and builds as speed occurs. The total amount of possible pressure is limited by design. Even if you accelerated twice as fast the pump has a design limitation. Now, to be fair I am not sure of what this limitation is, but I am sure there was a lot of thought when designing it at Porsche.
Anyone have a rad they want to blow up? Run a pressure test to failure and see what pressure will do it. Then stick a pressure gauge in Rob's car and see what is generated there. It will certainly prove or disprove this theory easily.
Like I said....I'm just passing on what I've been told. What you or I are convince of is a moot point.
It is possible that the radiator guy (who only fixes radiators and has done this exclusively for 50 years) I use is completely full of crap, enjoys lying to me, and knows nothing at all.
I will give him credit for one of the statement he made:
"Well you know damn well it didn't leave the Behr factory with this tank pushed out and leaking like it does, right now....it's been on the car for an entire year, with no problems".
Tough to debate that.
