Need "Junk" 87+ cylinder head
Does anyone have a junk 87+ cylinder head laying around? I have a couple spares here, but they are good usable cores (except for my only R5 GTS head which I want to keep for templates). Deck can be trashed, valve bores wallowed out from timing belt failure... etc. I want to do some destructive inspection of intake ports, and try and do some injector placement testing/measurement.
Hans
Hans
Still looking for a junk head if anyone has one. I would love to slice it open for injector spray pattern testing. Getting closer and closer to slicing up one of my viable heads....
Hans
Hans
Hans,
I know you are looking for a donated Junk head, but have you tried 928 International or DC Automotive, they might have a junk one at a low cost. You could also try Losangelesautoparts on ebay, they also are quite reasonable.
Hope that helps and saves a good one from being used.
I may take you up on that Mark, as long as its bad to a point it cant be repaired. I dont want to take any out of circulation. I am going to double check my inventory, but think all mine are useable.
Someone out there has to have a head that is unusable after a rod failure or other catastrophic incident.
Hans
Hans
