Could an exhaust leak...
... right behind the cats cause:
a) lower fuel economy
b) higher idle
c) both, or
d) none of those, just more noise
b) higher idle
c) both, or
Just noise, all of the other choices are caused by vacuum leaks and marginally affected by a bad O2 sensor.
Since it is from behind the cats it couldn't affect the Lambda unit as the O2 sensor is in front of the cat.
I was thinking since the cats aren't that long there might be chance of O2 "interference" from the leak. No? Too far fetched? I guess I will start looking for a vacuum leak.
