Charging woes 89 S4
Charging woes 89 S4
So here is the situation, when idling or running normally my voltmeter reads 13 volts.
When I turn on the blower motor to position 4 it drops to 12.5 volts.
When I add the rear window defroster it drops to 12 volts and when I add the headlights it drops to 11 volts.
The voltage does NOT change with RPM.
I rebuilt the alternator several years ago with new brushes and regulator.
Any thoughts as to what is going on here?
PJM
PJM
+1 what Bilal says. Volt gauge on dash is an rough idea. Use a voltmeter at the battery or the jump post and get real numbers.
