928 Forum 1978-1995
Sponsored by: 928 Specialists
Help needed- interior
Old Oct 6, 2013 | 08:19 AM
jorgens's Avatar
jorgens
Default Help needed- interior
Hi All.
I bought parts of a newer interior from a GT/GTS for my 81 model.
As I started with the rear seats and console, I see that the hinges/ attachment of the rear seat back is different- anyone have a picture of the arrangement of the mounting? I`m trying to figure out what parts I`m missing.
While I`m at it- I also bought a dash from the same car. Anyone did this job before on a older car?
Cheers
Jørgen
Old Oct 6, 2013 | 11:47 AM
Nicole's Avatar
Nicole
Cottage Industry Sponsor
Is your 81 a manual transmission car?
Early manual transmission cars have different sheet metal in the rear seat area, because the manual transmission is much smaller. As a result, the rear seats on early manual transmisson cars are wider.
Later, they consolidated the two styles of bodies and rear consoles/seats into the one with the sheet metal for the larger automatic transmission.
Old Oct 6, 2013 | 03:11 PM
jorgens's Avatar
jorgens
Yup, it`s a manual car- Found out about the hinges, some drilling and welding is required but will solve the problem :-)
Thanks, Jørgen.
Old Oct 6, 2013 | 05:50 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
I was going to use a later style rear center with the cubby hole. But left a giant gap and did no line up right. Ended up using my stock ok one..
Old Oct 7, 2013 | 01:02 AM
jorgens's Avatar
jorgens
I saw the same- But some kind of foam under the carpet will fix it I think.
