928 Forum 1978-1995
Sponsored by: 928 Specialists
removing the cam gear
Old 09-26-2013, 05:28 PM
johnu
johnu's Avatar
Default removing the cam gear
Still working on the TB/WP job, and I am trying to remove the crank gear. I have tapped the woodruff key with a hammer and used some pb blaster but still can't get the crank gear off. I can't get a gear puller behind it either. Any tips?
Also trying to get the oil pump off. Do I have to remove the rear tb cover? Any hints on this one?
thanks
John
Old 09-26-2013, 05:41 PM
Ducman82
Ducman82's Avatar
i used a 3 jaw puller to get the crank gear off. the pulley for the OP, i used a smaller gear puller.
Old 09-26-2013, 05:42 PM
Avar928
Avar928's Avatar
Watching this thread because I'm in exactly the same position. I can't find a decent sized puller to fit around it. The shaft is in the way. I've been trying to get the damn gear off for the past 2 days.
Unfortunately I can't leave it alone because the washer behind it is all mangled up now and some of the teeth got bent on the edges so now I have no choice but to replace it.
EDIT:
What size puller did you use? I've tried 2 and 3. Too big, I can only get one jaw on. Two small, shaft in the way. About to give up...
Old 09-26-2013, 05:44 PM
Lizard928
Lizard928's Avatar
The crank gear is tricky, soak with a penatrating oil for a while. You may need to damage the backing washer to get it off.
The oil pump gear needs to be counter held to get it off.
Without a special tool take a big screwdriver and put it through one of the holes and put it up against a rib on the pump. Use this to prevent rotation while undoing the bolt.
Old 09-26-2013, 05:54 PM
Avar928
Avar928's Avatar
^ What Colin said.
The oil pump gear wasn't bad for me. Jam a screw driver than socket wrench on the bolt to loosen it. It was still stuck on there so I used this:
http://www.harborfreight.com/automot...ler-66868.html
Two pronged but the stock bolts for the tool are short. So I used the long 10mm timing belt cover bolts to connect the prongs and then the gear came off. I'd suggest having some help to balance it, a PITA to do it by yourself.
Old 09-26-2013, 06:14 PM
snoz
Addict extrordinare
snoz's Avatar
My cam gear came off by hand after a brief fight. I'm in the about the same boat for the oil pump. I believe you will need to remove the plastic backing plate if you want to remove the pump itself, but not for just the gear. I was able to put my puller fingers in through the holes in the oil pump gear to pull it off.
Old 09-26-2013, 06:16 PM
Ed Scherer
Ed Scherer's Avatar
IIRC, I didn't have any problems using a Craftsman 46906 to get the crank gear off. Can't remember whether I had the puller configured for two or three jaws at the time. Probably used a temporary bolt to fill the crank bolt hole; I don't remember that, either. It has been awhile.
Old 09-26-2013, 06:26 PM
johnu
johnu's Avatar
I should have been more specific...the oil pump gear came off fine...I need to get the actual pump off
Old 09-26-2013, 06:30 PM
Avar928
Avar928's Avatar
Dwayne's guide says to try a lever, block of wood against the engine block, put the center bolt back on but not all the way and use a long crow bar (or one with a hole that you can screw on) behind the bolt to work it out.
http://dwaynesgarage.norcal928.org/1...0Procedure.htm - Chapter 10
Could also try to screw a "handle" to it, a piece of metal with a hole large enough to have the bolt go on and just pull straight out.
Old 09-26-2013, 06:33 PM
snoz
Addict extrordinare
snoz's Avatar
I just checked the backing plate, and you may be able to remove the pump without removing it. I removed the backing plate fist.
Old 09-26-2013, 06:37 PM
Avar928
Avar928's Avatar
Thanks Ed.
Going to stop by Sears to return this 2-jaw puller (too large) and see if I can finally get this thing over with.
Old 09-26-2013, 08:34 PM
fraggle
fraggle's Avatar
Mine were easy... of course I had the cams out on the bench at the time.
Old 09-27-2013, 03:48 AM
Avar928
Avar928's Avatar
AHAHAHAHAHA I finally got it off! Used the Craftsman 49605 2-Jaw puller that I bought and intended to return, just tweaked it a little, used some parts from another puller to create a platform against the shaft and slowly worked it off.
A layer of rust on the shaft kept it seized on there. Unfortunately the crank gear is no good. Worn down to the metal all the way. More parts to buy. Going to delay this job for a few more days.
Turned from a simple TB/WP to all gears to clean up and front end rebuild.
Old 09-27-2013, 04:30 AM
Ed Scherer
Ed Scherer's Avatar
Betcha it's really a 46905.
Old 09-27-2013, 02:37 PM
Avar928
Avar928's Avatar
My bad. 69. No pun intended.
Quick Reply: removing the cam gear
