Would a 944 S2 trigerwheel fit a V8?
Just bought myself a M28/42 (S4 auto) engine, and the triggerwheel is missing. I think I have the 60-2 motronic from the 3.0 S2, but would it fit? And is this possible to mix together with the clutch and flywheel from a M28/11?
If not, then what other possibilies do I have? Do some tuning specialists sell some other stuff I could use? And Is it possible to get hold of a triggersystem for a cam sync? I'm going to use the engine with a MS3X seq system for 8 cylinders.
Thanks,
Ronny
Thanks,
Ronny
only want to see is to try! LOL. not sure if that S4 engine has the cam sensor on the pass side or not. if so, you can use that for the cam sensor with MS. if not, you will have to fab up some kind of wheel and sensor to fit behind the cam gear.
Btw: Did I misunderstood you, or is it aqtually so that some of the S4's has a cam sync original? My engine is a 1990, so it is therefore a late model S4.
I have not seen the engine yet, as it is still in customs for declaration. Hopefully I have it in the weekend.
