Brake pad upgrade - do the rears too?
I'm installing PFC 08s on the front for track days (big reds). Should I be concerned about running stock pads (in good shape) on the rears? Rear calipers and rotors are also stock.
Fortunately the 08 rears are not nearly as expensive as the fronts!
Thanks in advance!
Thanks in advance!
Absolutely change the rears. So people run different compounds but the mix you have is too far off.
The fronts do most of the work but the backs contribute and you want it all, don't you?
