Alternator over drive pulley or not - that is the question
Doing the AC Delco upgrade this weekend and have an overdrive pulley. Goal is to eliminate the low voltage at idle situation I have with the dual electric fans and AC running.
Any long term experience with the over drive pulley installed?
Electron Wrangler
Electron Wrangler
Alan
Smaller pulley results in the alternator spinning faster at any given rpm therefore higher output at lower engine rpm's. He is not looking to do the old hot rod hp saving trick of running a larger pulley to slow the alternator down.
Correct for the pulley on the alternator...NOT the crank.
Team Owner
please post a picture of the pulleys your thinking of swapping.
NOTE there will be a pulley diameter that will bee too small for the belt to grip properly when the alternator has a very high load.
In other words the belt will slip even though you have made the belt tight.
NOTE damage to the main bearing can result from over tightening the belts,
this damage will occur when the engine is started since no oil pressure is available
How tight is tight enough without risking bearing damage?
Chronic Tool Dropper
The tension on the belt isn't related to pulley size, except when there's a temptation to put too much tension on the belt when trying to solve a slippage problem with a pulley that doesn't have enough contact with the belt. I use a rule of thumb, with moderate thumb pressure in the middle of the span giving a deflection equal to half the thickness of the belt. That makes the ribbed alternator belt pretty darn tight.
For those playing along at home, ribbed belt tension and slippage are somewhat counter-intuitive. First, you don't get much if any noise from a ribbed belt that's slipping. Second, a ribbed belt may slip more at idle than at speed.
I would wager a beer that many of us who suffer from low idle charging could replace the alternator belt, set the tension correctly, retension after a few hundred miles, and find a lot of those idle charging symptoms would mysteriously go away.
Caveat: I don't drink cheap beer, but you do...
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I'll wager a beer with you. Granted, I don't have any charging issues at 13.4 V at idle w.Ac, lights and defroster on but I'll still wager a beer with you. Holy Ale (tempered with burning witches) works for me. That or a good bottle of Vintage Ale.
It's a sucker bet, with some vague reference to "many of us who suffer". But I'll swap beers with you anytime. I'm cheap and don't drink enough beer to have a favorite. "Cold" and "wet" are primary criteria. Turns out I'm a cominsuer of beer.
