Will this fuel pump work in a 1982?
http://treperformance.com/i-7568325-...1980-1982.html
140 liters is 37 gal. 43 PSI.
Has anyone used one of these???
Just get the real Bosch unit, it is only $20 more
Bosch 69475 Original Equipment Replacement Electric Fuel Pump : Amazon.com : Automotive
http://s287999742.e-shop.info/shop/a...0104%252001%26
If your car is CIS/K-jet, its definitely not suitable - you would need a system pressure of 75psi. IIRC L- and Lh-jet need round 45psi, so it might be marginal for those as well...
jp 83 Euro S AT 55k
jp 83 Euro S AT 55k
Basic Sponsor
Correct fuel pump for a US 82 is 928 608 104 01 or Bosch 61 417.
69475 is not the correct pump but also not saying it would not work.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Dean, how are you doing man? Not talked with you in a long time.
Why will the pressure regulator need adjustment with an 044 pump please? If its correctly set now, will it be overwhelmed with delivery? I had an S4 pump on my CIS car for years, and it delivered spec pressure and volume fine, at up to 120F, despite being technically a lower pressure unit.
jp 83 Euro S AT 55k
jp 83 Euro S AT 55k
