928 Forum 1978-1995
Sponsored by: 928 Specialists
CPS Question and Removal.
Old Aug 15, 2013 | 12:02 PM
MainePorsche's Avatar
MainePorsche
Default CPS Question and Removal.
Guys,
Doing some preventative and repair work. Have the intake off and wanted to change out the CPS in that it is likely the original one there. I note the electrical connection from it ends in what looks like a test port which is unattached to anything. Is this supposed to be the case ?
Thanks,
Craig
Old Aug 15, 2013 | 12:15 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
two sensors. the on on the block is the CPS, the other is a test sensor for diagnostics. leave it, take it out, its useless unless you have the factory tool
Old Aug 15, 2013 | 12:26 PM
Avar928's Avatar
Avar928
The one that is mated to a female connector on a bracket in the valley just in front of the MAF is your CPS. Soak it in PB blaster, take the screw out that holds it down and very very gently pry it out. I rotated it while slowly applying upwards pressure. If it breaks off in the cavity, I believe you can still dry to drill and pull it out or else you'll need to go from underneath to the bell housing and tap it out.
Old Aug 15, 2013 | 12:33 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
let that baby soak in a BATH of penetrating oil..... you can drill it out, but that is just no fun!
Old Aug 15, 2013 | 12:38 PM
MainePorsche
Guys,
My error.
I wrote to soon. I see the CPS that I need to access. Will remove the throttle cable wheel to access it better. Will begin the soak now.
Thanks,
Craig
Old Aug 15, 2013 | 01:51 PM
oaros's Avatar
oaros
what's the take on prophylactic CPS replacement?
Old Aug 15, 2013 | 01:59 PM
MainePorsche
Been having idle issues.
Replacing ISV.
Was told in other posts that CPS could be involved, and thought to replace while there.
Old Aug 15, 2013 | 02:05 PM
Avar928's Avatar
Avar928
I had issues with cuts on acceleration during hot days (stopped, then I punch the accelerator and the engine "dies" for a couple seconds before she goes).
Replaced the CPS at the same time while fixing hose leak and I don't have that issue anymore.
Old Aug 15, 2013 | 02:09 PM
MainePorsche
My engine runs great.
It is my idle that is problematic - cold worse than warm. Been through everything. Thought I'd service to a new CPS while there after 27 years.
Old Aug 15, 2013 | 02:23 PM
oaros's Avatar
oaros
Ah - I see. Thanks
Old Aug 15, 2013 | 02:28 PM
MainePorsche
Ah - I see. Thanks
Thanks for the reply.
Specifically, what does a problematic CPS give one ?
Old Aug 15, 2013 | 03:05 PM
MainePorsche
CPS out.
Wasn't as I bad as I thought for I have read all the horror stories.
New one should be here tomorrow.
Old Aug 15, 2013 | 03:41 PM
MainePorsche
BTW, used plastic cutting Dremel wheel. Got the bolt end plastic cut off easily. Used a small handsaw to cut in between sensor and bolt head. All the plastic fell off nicely. Allowed for penetrant to get in there. Bolt and sensor came out like a breeze.
Old Aug 15, 2013 | 04:40 PM
MFranke's Avatar
MFranke
Good job!
Old Aug 15, 2013 | 05:17 PM
Avar928's Avatar
Avar928
The bolt was a PITA for me. I used a hex key then tightened a small adjustable wrench to it so it was perpendicular to give me more surface area to pull on it and break the bolt loose.
Scrubbed the threads and put a hell of a lot of antiseize on that bolt upon reinstall.
