928 Forum 1978-1995
Sponsored by: 928 Specialists
Do sun roof motors get tired?
Old 08-13-2013, 05:11 PM
Ducman82
Ducman82's Avatar
Default Do sun roof motors get tired?
New guides, greased tracks... she just does not have the "umph" like she use to. i have to help her forward and up. when up it seals fine. do the motors wear out or just get old? i have a spare (missing the connector) i was going to try and spray some more lube (and check) back by the motor and trans.....
Old 08-13-2013, 05:27 PM
extanker
extanker's Avatar
sure electrical motors get tired. just check voltage/grounds etc and make sure the glass is free to move. any other electrical issues ?drive cables ?how old is the battery ?
Old 08-13-2013, 06:08 PM
jeff spahn
jeff spahn's Avatar
What glass? You have a glass sunroof in your 928? Who made it for you? Links man, links! I want one.
Old 08-13-2013, 06:13 PM
Ducman82
Ducman82's Avatar
New batt, no other electrical issues. Slow even when the car is running.
Old 08-13-2013, 06:44 PM
928Myles
928Myles's Avatar
Have you removed and cleaned and lubricated the cables?
Myles
Old 08-13-2013, 06:59 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Time to replace it.
Old 08-13-2013, 07:25 PM
Ducman82
Ducman82's Avatar
i have another, i will give it a shot. clean and greased cables and guides. ill check to see how greased they are. used a little white lithium. maybe not enough...
Old 08-13-2013, 07:38 PM
syoo8
syoo8's Avatar
Did you actually remove the cables? My sunroof behaved the same way, it wasn't until I removed the cables, removed old dried gold grease "carcasses" that I had smooth motion restored. (They look like little pieces of acorn, and they are hard.)
Old 08-13-2013, 07:54 PM
Ducman82
Ducman82's Avatar
yup. took the whole system apart. even used my bore snake to clean the tubes. all is clean. either not enough grease, or the motor hates me. lol
Old 08-13-2013, 08:02 PM
depami
depami's Avatar
If you have another, start by comparing no-load RPM. And torque, if possible.
DC motors have brushes and a commutator that get dirty and or wear out.
Sometimes you can give it a second life by replacing brushes and resurfacing the commutator.
Old 08-14-2013, 01:25 AM
renbry
renbry's Avatar
I have the same issue - fast as ever to open, on close it slows down sometimes almost to stop !
Old 08-14-2013, 01:38 AM
syoo8
syoo8's Avatar
I have had that issue when the sunroof wasn't quite adjusted in the way that it wanted to be.
I just did the sunroof on my 86 (removed the tracks, guides, cable, cleaned everything, then lubricated the cable only.
When I reassembled, everything looked fine cosmetically, but the thing would hardly close. (!)
I disassembled again (and then followed Keith Widom's directions step-by-step.) Voila, now the sunroof closes even faster than it opens.
I hope that helps, I'm sure that you've adjusted it properly, just thought I'd throw that out there.
Old 08-14-2013, 04:05 AM
lonnie77
lonnie77's Avatar
Could be the four bolts that attach the moving bracket to the hinges are to tight. The two at the rear should be lightly tighten and the two at the front should just touch the metal. Or you need brushes.
Old 08-14-2013, 09:14 AM
Ducman82
Ducman82's Avatar
do you grease the tracks?
Old 08-14-2013, 09:40 AM
Kevin in Atlanta
Yes you lubricate the tracks. Grease is a mistake. You need a light lubricant that will not cake or accumulate grit. My mechanic used a Mercedes sourced sunroof track lubricant way back. Now I use aerosol based lithium spray.
Quick Reply: Do sun roof motors get tired?
