EZ steering rack boot installation tools
In this case the rack was on the car and only the inner tie rod ends were separated. I was having issues getting the small end of the boot over the tie rod inner end.
1) Make sure everything is clean, including the whole tie rod
2). Stick the boots in hot water from kettle for a few minutes and then shake the water off
3) lube the boot ends with dish soap
4) stick 3 plastic spoons into the small end of boot and orient them 120 degrees from each other with the handles sticking out of the boot toward the rod end
5) put the small end of the boot on over the inner tie rod end by pulling on the spoon handles It will go over the rod end and the rubber seal nice and easy with the spoons
6) attach and tighten the rod end to the rack
7) take two needle nose pliers and pull the fat end of the boot over the rack end and let lt snap in place
There you go - takes 10 minutes maybe.
jp 83 Euro S AT 55k
Maybe need a screwdriver to help it start.
jp 83 Euro S AT 57k
