Used motor to play with.... have a few questions.
Picked up the M28/44 from a fellow shark here in ohio to play with. Was a timing belt fail motor. most exhaust valve are trash, has a few of the valve cover stand offs broke in the head, but nothing major.
does this look like a deal breaker?
![](http://i575.photobucket.com/albums/ss197/Ducman82/928/New%20engine%20build/IMG_1696_zps2c5a7d3d.jpg)
here is a pic of what the cylinders look like. pistons are ok.
![](http://i575.photobucket.com/albums/ss197/Ducman82/928/New%20engine%20build/IMG_1697_zps48552662.jpg)
![](http://i575.photobucket.com/albums/ss197/Ducman82/928/New%20engine%20build/IMG_1693_zps575b422c.jpg)
what do i need to do to "update" this S3 heads. i hear i need the S4 tensioners... but any other tricks to a head rebuild?
You can call me Otis
...as per the first pic of the block, you've prolly seen this already.
http://dwaynesgarage.norcal928.org/1...k%20Repair.htm
Should be fine for a table, what are your plans for it?
I don't think the water pump impeller has a very tight tolerance, but maybe somebody knows a spec to check. Greg has a tool and fix, or do you need perfect for a special reason?
Going to take my time and build this sucker for boost. i can completely take her apart, send the block to Kuhn for a little bore and plate treatment... or leave the bottom end alone and just roll with it.
cleaning her up right now. if i cant use this one, im sure i can find others. i can always sell the cams and make my cash back.
Dwayne has an excellent "how to" for the water pump block repair.
http://www.dwaynesgarage.norcal928.o...k%20Repair.htm
What is the piston tolerance number?
