Brought home for the first time.
Oh, and I am crazy enough that I want to daily drive it! But I knew that an 86 stored for so long would need some TLC and be something of a project at first
Nicole asked for an interior pic. Interior is in great shape, seats look very low mileage, back seats look never used. Only very mild leather warp on the dash around the glove box, but with no pulling anywhere except for the trunk which needs stretch/staple. I have the A/C **** but I didn't put it back on before this pic.
Aside from the no dash lights, other interior to-do's:
- shift boot is in nice condition but pulled loose, need to re-attach
- steering wheel is tight left/right but has about 2mm of play up/down, need to figure out how to tighten that
- restaple trunk leather
- new, darker tint for windows
- figure out how to make the door speakers work (only rear seat speakers work), or otherwise I'll put in new speaker system
- driver door seat release switch missing the plastic peg
The dial next to the ebrake may be the fader, give it a twist. If it is a light switch, this may be a euro with the manual headlight adjusters. Take a pic and show us what's there!
As for daily driving, don't know your commute in Vegas but if it has stop and go or slow city streets you may become disenchanted with the car, at least that is how it often works. These cars were made for the autobahn and they excel at that sort of thing and handling curvy sections. They also don't like sitting in hot stagnant air.
After everything is sorted mechanically you can begin to get to know it's abilities. A member here, Porken sells chips and other items that will perk up the engine even more. Some new wheels are being developed that may appeal to you.
So far I would say you lucked out on this purchase.
The vibration if it is felt thru the steering wheel is most likely a rebalancing item or if felt thru your butt may be one of a number of things including TT but at such low mileage I believe it will be simple, even flat spots.
Fixed that - turns out the solution was "turn the dial under the left of the cluster back and forth quickly a bunch of times." :P
Cottage Industry Sponsor
No, all instruments work fine. No cabin/overhead or dash lights at all though, and the light **** on the floor to the left of the driver's seat doesn't do anything. I hadn't driven it at night until yesterday so that wasn't known. The headlights and foglights all work fine too.
Feels like mild shaking between about 65-75. Smooths out after that, which leads me to think wheel balance or tire wear for one of the fronts. I'm hoping to get some 17" BBS Sport Classics (the 996 style) later in the summer so I'd rather not replace tires yet if possible.
Once it shrunk and pulled-away, it's kind of hopeless... You may be better off having it redone in vinyl, so it won't dry and shrink again.
Most importantly: keep the sun out of your interior! You may consider getting a set of fitted window shades for all of your windows. You can search for "Heatshield" here on this board - you should find some pictures of what they look like. I carry them in my online store, but that's not why I recommend them to you - I really think it will help your black leather last longer.
First off, thanks so much for your responses! This is a great community.
After reading for a few hours last night on different issues, I'm 90% sure it's the "dome light grounding" issue and fuse #24 that's affected. There are at least three others who had this recently.
It was actually just a lose bolt for the wheel itself. I read here, went and bought a 27mm socket and was able to tighten it up in about 5 minutes.
Yeah, I'm also going to get a dark tint ASAP. They're pretty mellow about tint in Vegas.
Replaced both cats yesterday, that got rid of the strong smell during and after driving. Also made it more the exhaust more resonant and 5-10db louder.
Re the shake at 65mph, make sure your lug nuts are all torqued down appropriately. 96 ft-lbs. It's a little thing often overlooked.
Car looks great !
Best wishes.
Car looks great !
Best wishes.
Ugh. It's worse than I described - I must be down 200hp... I just went around about 6 miles and it took me about SIXTEEN seconds to get to 60mph. It could barely go faster even in third.
