Don't Ban me - why not an after market radiator?
#121
MJ
#124
#125
One is designed to cool an inline 4 cylinder and the other designed for a V8. Capacities are a huge issue. It may cost 1/2 as much, but it also has 1/2 as much cooling capacity.
#126
Developer
OEM is available.
Just very expensive.
And..the same price as a proper Alum radiator..so..why change
2) to bring your temps down
3) to avoid installing plastic end tanks again, which will fail (again).
Some of these "new" radiators are NOS (New Old Stock). When this happens, the plastic has been hardening and aging for years on the warehouse shelf before you bought the part. The embrittlement of the end tanks has begun before you got the part. This does not apply to new new radiators (just manufactured)
#127
Basic Sponsor
Stick with the original Behr radiator if you can afford it - they last for over 30 years and failures as a % of the numbers made are negligible. Behr radiators can only be purchased via Porsche and they are of current manufacture.
If your original has a leak at the plastic end tank, replacement with one of the newly manufactured plastic end tanks is very straight forward and relatively cheap. It is best to find a good radiator shop with the Behr press tool to have the tanks installed. Good tutorials are available on Rennlist for how to do this yourself.
Aftermarket aluminium radiators are historically fraught with issues and contrary to what some suppliers say they are not plug and play. Often they are wider than the stock radiator which causes fitment challenges especially if you plan to mount a SC.
On the positive side they are cheap - but you get what you pay for.
#131
Here's a potentially dumb-assed question: How about an aviation radiator?
#132
Chronic Tool Dropper
... Like the ones in early 911's?
#134
I find it hard to believe with the thousands of car models out there that there is not an identical radiator as used on the 928 at a reasonable price.
I'm thinking there's a radiator guy somewhere that upon seing our radiator will say, 'Yeah, the 1984 through 1993 Mumbleschmitt uses that exact same radiator. I can get a new one for $279.'
#135
Basic Site Sponsor
Basic Site Sponsor
That should be the very last post, in this thread. End of story.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
