alternator and powersteering
I followed [loosely] these instructions http://dwaynesgarage.norcal928.org/1...0Procedure.htm, so thanks to Dwayne for the great guide.
thats the bracket. it was sheared apart, but the engine block is ok so thats better than the worst it could be (as he hesitates to say good).
I'm a little worried about the oil pressure sensor? as Dwayne's didnt have a hole like this, and since the incedent, when running, my car leaks a little bit of something (cant tell if its oil or PS fluid). I think it could be oil since the PS pump is lacking a belt. I think that is what happened to my PS, it lost the belt and stopped working, but if anyone else sees anything wrong in the photo that I missed please tell me.
the PS pump. it's hanging on the tubes because I didnt have the right size wrench to get them off, and Dwayne left his hanging it seems, so I think its fine?
the closer belt is just straight up loose, I think it goes to the fan and air pump or AC? the other belt goes to the air pump or AC? and I dont think it should be side ways like that, am I right?
I'm trying to think if I left out anything I wanted to ask...
Finally, Dwayne's 87( had skid plates underneath it which he needed to remove before working on it, but mine (86 auto) did not have skid plates. is that a difference between the 86 & 87 or did the PO leave the plates out aswell?
BTW you should get aluminum belly pans but that too can wait.
as to the skid plates/belly pans for an 86 would that have to be aftermarket or were they supposed to come with?
Good luck,
Dave
Your alternator needs to be replaced/repaired. I would be interested in this unit. Or can repair it for you. PM me.
Also the upper bolt for the alternator goes into the block, please photograph this area too. In your picture showing the hole in the oil pressure sensor (needs to be replaced), this bolt hole is behind the power steering pump bracket shown.
In addition to replacing your shocks and setting the car to stock ride height, you should also replace your motor mounts. These two items combined will ensure that you do not have this occur again.
If you search "Ride Height" in thread titles on this forum you'll get 118 hits.
Here are some good ones:
https://rennlist.com/forums/928-foru...de-height.html
http://jenniskens.livedsl.nl/Technic...2/MyTip291.htm
http://www.928.org.uk/13-setting-the-ride-height.html
And you wouldn't really be "adding" height, just putting it back where it belongs, which would maximize the ride quality and handling.
There are a lot of people who think the 928 looks better when it's lowered an inch or two from where it belongs. I won't argue about appearance, but it does adversely affect ride quality, handling and ground clearance.
And if your motor mounts are original, you will want to replace those too. Squashed mounts lower the engine almost an inch (I think). Combine that with dropped ride height and those lovely PA roads and you might think about stocking up on alternators and brackets if you don't do anything.
Most of the weight rides on the springs anyways. Shocks are mainly for dampening the recoil or bouncing. Sure they have bump stops at max compression. Hopefully, you aren't hitting those. Crank up you ride height if it's too low, but then you will need to adjust the alignment as well.
If the roads our that bad, you could get a set of Carls extended skid plates. Like I said, get it fix for the season, drive it till winter... then you can sort out and prioritize other issues. That's what I would do if I were you.
I am partial to Auzivision's advice. Fix the immediate issues so you don't end up spending the rest of your life not driving but fixing. It can be a slippery slope.
My only other advice is where 928Intl has a USED part, buy it. Their USED parts are quite good and your link to the alternator bracket was for a new one at 2x or more the cost of USED.
Good Luck and let us know how you go!
@Lizard928 the screw hole for the adjuster on the alternator broke off, so unfortunately it would be difficult to fix, even with a welder. but I think it does still work.
what concerns me most immediately is the alternator and belts and not the suspension.
this belt (the one in the back of the photo) looks a little off, am I right that it should not be twisted as it is?
EDIT: thanks also auzivision and jej3, thats probably what I'll do for the springs and stuff, but the ride height is easy enough that I can do it in an afternoon and be done with it. also thanks for the tip about 928intnl's used parts I had found a used bracket on them for like 90$ instead of 190$.
Good luck,
Dave
My suggestions would be to:
- Buy a used bracket and oil sensor from Mark or someone else.
- Unless the belts are really good, buy new belts.
- Check the alternator very carefully for damage.
- Do some research here for adjusting the ride height, then set the height at or near the specifications. You will then need a four-wheel alignment by someone who knows how to align a 928. If the alignment shop tells you that they have to lift the car to check it, or to set their equipment, walk away and find someone who knows how to align the car. You must do an alignment (at least toe setting) after changing ride height.
