What did you do to get ready for SITM?
I know we are all frantically getting our cars ready for SITM. I thought it would be neat to see what everyone is doing and what some of the common items are.
I will start.
-new spark plugs and wires
-87 FPR
-Ken's chips
-chased vacuum leak in hvac and disabled vacuum line to comb flap (temporary)
-re-painted sunroof
-fixed loose centre console with jäger kit
-pulled after market alarm and all wiring
-pulled stealth 80's radar detector and all wiring
-installed TQ rings
-cleaned oil from intake plenum s
-changed oil and filter
-tightened up rad hoses
-released tension on flex plate and re-torqued clamp and p-klamp
-lined hatch with cache sound proofing
-cleaned fuel sender contacts
-had AC system vacuumed and filled with dye and r134
-clean, clean, clean and clean
I will start.
-87 FPR
-Ken's chips
-re-painted sunroof
-installed TQ rings
Changed oil and filled with valvoline VR-1.
Still trying to button the AC system up with all new O rings and a new compressor. Will install the new compressor tomorrow and pressure test, vacuum, fill up with R12.
Will also check tire pressure before I leave.
Here's my list....
Here's my list.... (one of the reasons I REALLY love SITM!)
Mechanical or Safety Related
Aesthetic
Infotainment
Other
- Replace Windshield (Due to Crack @ last year's SITM)
- Coolant Refresh with Water Wetter (to do - might not get done)
- Release flex plate tension and Re-tension Porkens + Original Clamp
- Make Minor Adjustment to steering wheel
- Replace fuel pump
- Replace any suspect 53 relays
- Check Transmission Fluid
- Change oil and air filter
- Recharge ac
- Replace passenger side fuel line
- Clean grounds
Aesthetic
- Re-Paint and Add Decals to Calipers
- Install Jager Speedmount (motor mounts next year )
- Install Jager Lock Dress Up kit
- Install Nicole/Jager's Rear Nickel Letter kit
- Install Clear turn indicators from Nicole in Bumper and on sides of car
Infotainment
- Correct Left Side Channel intermittent fail on Stereo (two new sets of RCAs to Pre-Amp corrected)
- Configure Microsoft Surface for Road Trip
-Purchase Windshield Mount
-Procure usb gps
-Add 5000 song music library - Purchase lightweight inverter in case needing charge while driving
- Install Powerport(s) in passenger footwell (to do)[/INDENT]
- Crack Windows Mobile Phone to act as a hotspot for in-car Internet
Other
- Full detail (to do this week)
- Renew AAA Premium Membership
- Make tee times for Sunday or Monday in/around Banner Elk
Installed Greg Brown fuel hoses
Checked and topped off transmission fluid
Replaced dash light bulbs that were burnt out
Installed p-klamp and released tension on flex plate
Damn Harvey...slow down!!!
I got her loaded up to go to the muffler shop....clutch is grabbing much better...must have just been rusty. Borrowed trailer is a bit narrow...I put a scratch on the fender...dammit!
I'll post the pic tonight....for some reason all my pics are suddenly too large, and I have to edit them down on the computer....
