928 Forum 1978-1995
Sponsored by: 928 Specialists
Where is my coolant going???
Old 05-17-2013, 12:47 PM
sharkbate
sharkbate's Avatar
Default Where is my coolant going???
I've had to fill up my coolant 3 times over the last 2 weeks. I'm not seeing anything on the driveway to indicate a leak. Thoughts??
Old 05-17-2013, 01:15 PM
John Speake
John Speake's Avatar
It's leaking on somewhere hot and evaporating. Look for tell tale traces of dried coolant..... often greenish in color.
Old 05-17-2013, 01:26 PM
chrisjbell
chrisjbell's Avatar
Or its exiting via combustion chambers and exhaust. :-P Either way one of the head gaskets would be a likely candidate... out and hitting the headers or into a cylinder, quickly vaporizing either way.
Old 05-17-2013, 01:31 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
You may have an internal leak of your head gasket. This has happened to me before and had me stumped. As it got worse, I noticed that coolant was being pushed out of the overflow hose of the reservoir since the cooling system was being pressurized by the combustion chambers.
Get a cooling system pressure tester hooked up and pump it up to about 12 psi. If you see the pressure go down on the gauge, but no leaks externally, that is not a good sign.
Has your car overheated before?
Old 05-17-2013, 01:39 PM
sharkbate
sharkbate's Avatar
Nope. Never overheated. I just the the coolant indicator on the dash.
Old 05-17-2013, 01:42 PM
newworld
newworld's Avatar
Default coolant
lets back it up a bit here......
first, did u recently open up the system hoses, rad, pump etc? before you noticed it going down?
Old 05-17-2013, 01:50 PM
sharkbate
sharkbate's Avatar
No. The light came on so I opened the cap to put in more coolant.
Old 05-17-2013, 02:02 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
No overheating is a good sign. Can you pull the airbox off and check at the back of the engine? A leaking heater valve is also a likely culprit for mystery coolant loss. However, you would probably smell it inside while driving too, if it is leaking.
Old 05-17-2013, 02:11 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,442 Likes on 1,371 Posts
the two most likely sources are,
The top of the passenger side radiator tank it can leak and evaporate all at once,
look for white crusty deposits on the tank surface of the fins of the radiator front or back.
Next the heater control valve and or short hose, also check the block off plate and the HCV outlet for weeping at the gaskets.
What is the condition of the coolant bottle does it have any cracks in it?
Has the coolant cap been replaced recently?
Do you see any tell tales coming down the center of the top of the oil pan,
this is a water pump leak.
Are the coolant clamps tight at the water bridge and the radiator?
Old 05-17-2013, 02:16 PM
mike77
mike77's Avatar
Might be an idea to check the coolant reservoir cap is on tight and perhaps tighten up any hoses that are easily accessible.
Old 05-17-2013, 02:23 PM
sharkbate
sharkbate's Avatar
Thanks guys. I'll do some investigating. Appreciate the responses.
Old 05-17-2013, 02:43 PM
FBIII
FBIII's Avatar
Check to see if the inside of the oil cap is milky and if there is a lot of condesation.
Old 05-17-2013, 04:42 PM
Chalkboss
Chalkboss's Avatar
I had the same issue. Turned out to be a small leak at the water bridge where it mounts to block. Suprising amount of loss from a slow seep. Look for white crusties.
Old 05-17-2013, 04:59 PM
Stromius
Stromius's Avatar
Mine leaked at the O ring in front of the oil filler and had a bad hose between the reservoir to waterbridge that also leaked into the areas.
Old 05-17-2013, 06:14 PM
The Fixer
The Fixer's Avatar
Look at the res Cap, check it is on correctly and look at the rubber seal.
Get it up to temperature pop the hood and look carefully.
Quick Reply: Where is my coolant going???
