928 Forum 1978-1995
Sponsored by: 928 Specialists
Restricted Air Flow!
Old 05-24-2013, 12:24 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
I have never measured the size of the barn door opening - perhaps 1 1/4" x 2 1/4"? If so, that is about 2 3/4 square inches of opening.
A NASCAR plate engine used to make about 650 HP @ 9000 RPM from four 15/16" venturis, which is just about the same area...
Of course, the rest of the intake tract and the rest of the engine are a little different.
Old 05-24-2013, 12:27 AM
The Fixer
The Fixer's Avatar
Old 05-24-2013, 12:31 AM
The Fixer
The Fixer's Avatar
Old 05-24-2013, 12:39 AM
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
Originally Posted by The Fixer
Hey Dave, I didn't include this pic but i marked the factory setting with a white dot of paint and rotated geared wheel C.C. 10 positions to start. I stopped at ten because it is where i could start to feel a tension difference. I may try a few more spaces. I may also port some more some day. Just take your time removing the plastic cover of AFM mechanism so you don't damage it. It is siliconed on but it was really on there. I went around and around slowly applying pressure upward until it started to lift off. I used black silicone to reseal after cleaning all the old adhesive out.
Hey I will not need your most generously gifted part, tuns out it is not the issue, I will hold onto it for you or I can ship it back.
You should have it in case you need it.
Matt
Matt, feel free to keep it. Someone else may need it and you can pass it on. If you'd rather not, of course you can return it.
Dave
Old 05-24-2013, 06:16 PM
The Fixer
The Fixer's Avatar
Old 06-27-2013, 07:17 PM
robot808
robot808's Avatar
The Fixer,
May I ask why these posts were edited out?
Old 06-27-2013, 07:57 PM
Ducman82
Ducman82's Avatar
i thought the answer to life was 42? not 12...
Old 06-27-2013, 08:26 PM
Fsharp9
Fsharp9's Avatar
Location: Wrong Island NY, 04 CTT , 1984 S 5 Speed Slate Blue Metallic
WTF ......this was just getting interesting
Old 06-27-2013, 08:48 PM
SMTCapeCod
SMTCapeCod's Avatar
Again?
Fine, 13.
Old 06-27-2013, 08:52 PM
SeanR
SeanR's Avatar
Old 06-27-2013, 09:00 PM
BC
BC's Avatar
I thought we were not allowed to pull posts like this.
Old 06-27-2013, 09:26 PM
SMTCapeCod
SMTCapeCod's Avatar
Naw just you...
Must be that special 'Avatar relief' clause...
Old 06-27-2013, 09:38 PM
SMTCapeCod
SMTCapeCod's Avatar
Naw just you...
Old 06-27-2013, 09:41 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Originally Posted by SeanR
14
Blow me.
15.
Old 06-27-2013, 09:42 PM
SeanR
SeanR's Avatar
Originally Posted by Speedtoys
Blow me.
15.
I've roomed with you, not worth taking my teeth out.
16
Quick Reply: Restricted Air Flow!
