Blakpundt reno wiring
Stock radio....87s4.
I can see on rear radio the following
Ground connection then 12v switched,then antenna connection, then 12v constant.
My wires from car I can see brown wire which I assume is ground, then I have 2 red wires one thicker then the other....
Am I to assume the thicker red or lower guage is constant 12 v?
And thinner or higher guage red is switched 12 v?
I assume antenna can be left unplugged
does this plug directly into back of radio, or is there another plug that goes in then goes to radio?
the reason is that in back of radio, from left to right, is
[ground] [switched 12 v] [antenna] [constant 12v]
the ground and switched 12v are bigger plugs, the constant 12v is thin plug
radio
thanks 86_5tiburon....that helps tremendously.....that means i can hook up
thick ground then thick red then skip skip then hookup thin red.....
the white wires i think are antenna related, or alarm? im not sure, but i dont think they are critical to radio function.
thanks ahead of time for taking photo etc, that helps a lot.....
