Gates Timing Belt Comparions - Regular vs Racing
#31
Twisting the belt, or defecting it, increases the path length for the belt and compliance has to come from something, either the belt stretches or some other part of the system moves to compensate. The Kempf and the 9201 both increase the path length and measure the force that increase requires to estimate the tension of the normal path length. Pretty obviously when the force required to stretch the belt during the measurement varies from stock, the estimate of the non stretched tension is going to be off.
OTOH as long as the tension isn't so high it damages something, or low enough to skip a tooth, does it really matter much? A little variation in valve timing maybe?
#33
Your 928 is a US 16-valve S. If your timing belt breaks for any reason, it is extremely unlikely that there will be any internal engine damage. You are worrying too much.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
#34
Basic Sponsor
With over 150 Gates 928 RB sold and probably well over 100 in service and not to mention the thousands of RB's used on other cars such as 944/951/968, Subaru WRX etc. etc. I have not heard of one issue at all.
This is not a new belt designed for the 928, Gates just applied the belt technology to the belt for our car.
I have learned to trust the Gates engineers as they know what they are talking about, it is after all their business. It is certainly not in their interest to make false statements.
If you use a PKensioner, belt tension would never be an issue 8>).
#38
Porsche knotched my pistons for no reason?
Or is that reason so no damage will occur?
I will be installing high lift Euro cams as i said, so damage will occur.
This is a beaten issue i know but I have read conflicting reports.
Thanks though Dan.
Going with stock belt anyway.
Matt
Thanks though Dan.
Matt
Dan
#39
I haven't had my hands on a Racing Belt but I can't imagine that it is significantly torsionally stiffer than a normal belt. If it were it would also be significantly stiffer in bending which would then cause lots of issues where it wraps over the smaller tensioner pulleys.
#41
An interesting thread- nothing too contentious. My 2 cents worth is that a stock system installed correctly will work nicely without excessive wear on the cam gears but then I am not the hardest user and for sure not the furthest driven 928 owner.
I am seriously considering the racing belt for my next belt change simply because I like insurance of additional heat resistance insurance and I am thinking about the Porkensioner simply because I have a lot of confidence in the stuff Ken comes up with and my stock kit is now 20 years old.
I rather suspect belts fail because of one of two things - incorrect installation or failure to replace critical kit, however there can and will be exceptions. I have not experienced a belt problem but then I have probably replaced way more than I should-I rather feel in our hot climate here time is as much a factor as use not mention that fact that "less use" can also be a problem if the engine sits idle for extended periods [mine does not].
Thus we need to differentiate between "good" and "better". If I was putting higher lift valves and stiffer springs in then it would be a "no brainer" for me.
The only thing I would not do, is run a belt without the covers no matter how I was using it but I do appreciate the dilemma of those trying to save every ounce.
Regards
Fred
Regards
Fred
#42
I had the gates racing belt installed before christmas and since then have had about 5 TB warnings, some just after start (like today), some when on the gas. When it first happened after about 300km, I took it back to the shop and they checked the tension and said it was fine. It happened again after about another 500Km and I took it back for a further check and it was still fine. Not sure what to do now, I suspect its not electrical as there is no real pattern to it but I don't really know. The workshop has suggested tightening the belt higher than recommended to see if that fixes it but that does not impress me at all so I will probably take it somewhere else. I have now 2,000km on the new belt.
Jason
89S4 auto
Jason
89S4 auto
#44
Jason
89S4 auto
Jason
89S4 auto
1) Higher-than-stock tension increases stress on all of the belt-related components, so that clearly is not a good answer.
2) You are having a shop do the work, which changes things compared to many (most?) folks here. A shop will typically warrant their work and will typically want to stick with factory-spec components to reduce their exposure, unless they have a lot of experience with a particular part.
3) The belt system is a "system", with the belt, tensioner, alarm, sprockets and pulleys all acting together. Everything has stretch (even the racing belt), the factory tensioner and alarm were designed to work in the context of the factory belt being part of the system. When you tighten the factory tensioner you are partly pre-stretching the belt, and partly compressing the bimetal spring-washers. A stiffer belt means less total compliance in the system, for the same tension. This is a fundamental change to the system.
The factory alarm is set to around 80% of the static tension (my measurements, consistent with other reports here). With the racing belt there will be less total compliance and greater variation in tension. So triggering the alarm, with the racing belt, with normal variations in dynamic tension would not be unexpected.
I suspect most folks here who are using the racing belt are also using a PKT (Porken tensioner). That changes two things: The PKT is spring-loaded and automatically changes length to maintain a relatively constant tension (with hydraulic dampening against compression), and it eliminates the warning. This is a fundamental change to the system.
It has been suggested above that the PKT is a good match for the stiffer nature of the racing belt. That may be the case, but I don't take it as a given: at some level it is simply two different fundamental changes.
In your situation, shop-maintained car and (I assume) relatively stock engine, I think a strong argument can be made for sticking with stock belt components-- factory belt and factory tensioner.
Cheers, Jim
#45
Twin Turbo Todd:
https://rennlist.com/forums/928-foru...ar-wheels.html
He made some interesting observations while installing the stock Gates timing belt on his new motor (5 liters, different pistons, different rods, nikasil block, worked over heads, stock valves, stock crank, stiffer valve springs).
Todd spent a considerable amount of time studying lifters and valve springs, bench testing about a dozen different valve springs to find the exact setup he wanted for this engine.
He ended up using is a non-Porsche spring that is about double the spring pressure of a stock 928.
While manually rotating the engine with a stock Gates timing belt, he noticed a considerable amount of stretch before the camshafts started to turn, "rubber band" came to mind.
Thankfully he already had a Gates Racing Belt from Roger @ 928's R Us to test.
The racing belt had zero stretch.
Since the racing belt new for Todd, he asked me to take some comparison photos as a reference to look back on as he puts miles on the new belt.
I figured these should be shared with the 928 collective group.
http://www.erik27.com/cars/928beltcomparison/
Please note - this post is not saying the stock Gates belt is not adequate for a stock 928.
Åke
