S4 Cutting out/stalling/idle problem
#31
Team Owner
any definitive solutions to this issue?
#32
To bump the tread and add my issues to it:
I had cold starting trouble where the car would either start, or just go Vroop, and then refuse to start for a 24 hrs.
On suggestions I changed the temp 11 and connector. Now my symptoms are as described earlier.
Cold starting require a bit of cranking, but then it starts. However, till it warms up a bit I can't apply throttle and it's clear the engine has no power.
In another thread ( that I didn't save) someone gave the hot and cold resistances for the temp 11. If anyone has those available and can share that will be great.
I am planning a top end refresh in the coming weeks and hope to not add to the issue.
#35
haven’t solved my problems yet with the car stalling when it runs. It won’t restart unless I jumpstart it with another car then it starts right up. Also sometimes when it ran and I shut it down it wouldn’t start unless it was jumped.
I feel it’s an electrical issue, the car just cuts out when running. Maybe The electrics are cutting out which causes the fuel pump to start. But then I would think it would start again on its own without having to jumpstart it. Without jumpstarting it the car just never catches, but it does turn over: it’s been two years now since I’ve done anything other than start the car every week or so. Now with all this going on I may take another crack at it starting with changing the battery ground, The 14 point connector, and anything else electrical I can think of that might help. Any ideas?
