Hood light tilt switch
Vegas, Baby!
Stan (Mr. Merlin) had a write up on repairing the switch, try search, it was a couple of years ago.
saw that. i have two merc switches, and i have cleaned them real good... nothing. if i shake them real hard, i get a slight amount of connectivity........ but not on its own....
Team Owner
also make sure the mounting screw into the hood is good.
no ground can cause the lamp to not function,
the mercury switch seems to work well if the contacts are clean,
add some dielectric grease to all surfaces
also swap in a new bulb as it will have cleaner contacts
