FS: 1989 S4 Euro with Sunroof Delete...
Picked up another S4 last week in B.C. at a Sheriff's auction.
Black on maroon/brown
Automatic
60,000kms
WP/TB work done
No service history
Colin has performed a PPI and says it won't take much to bring this baby fully up to spec.
Looking for $7,500.00 or ill start having the work done by Colin and you'll be sorry you passed this one up.
Sent from my iPad using Rennlist
Automatic
60,000kms
WP/TB work done
No service history
Vegas, Baby!
![](https://rennlist.com/forums/images/ranks/veteran_navy.png)
![](https://rennlist.com/forums/images/ranks/veteran_marine_corp.png)
Automatic
60,000kms
WP/TB work done
No service history
Automatic
60,000kms
WP/TB work done
No service history
Spark plug seal 8 $17.94
Valve cover bolt seal 26 $29.90
Valve cover sealing ring 26 $14.95
Valve cover gasket. 2 $29.90
Gasket Intake - throttle housing 2 $11.50
Gasket intake - side covers 2 $20.13
Intake rubber pressure ring 10 $27.60
Main intake gasket. 2 $37.95
Flappy Bearings 2 $29.90
Crank position sensor 1 $71.30
Knock sensors 2 $138.00
Hose Right front cam cover to oil filler 1 $35.42
Hose Right Y to oil filler 1 $34.51
Hose Right Y to cam cover 1 $32.57
Water bridge gasket 1 $3.45
Water bridge O-Ring 1 $3.00
Thermostat inner seal 1 $11.50
Power steering hose Pump reservoir 1 $17.20
Flappy vacuum actuator 1 $42.00
Ignition leads $200.00
Labour for replacement 10 $75.00 $750.00
$1,908.72
Power steering reservoir hoses require replacement. Hoses $28, 1 hour labour $75 $103
Drivers side CV joint boot is torn and badly needs to be replaced. $280 to pull and rebuild. $280 *
Fuel lines require replacement, $275
Window switches are needing to be replaced.
Suspension shocks are original and are worn.
Front and rear pads require replacement, front rotors need to be replaced, rears recommended as well.
It sure looks like a nice car and its a good thing I already have a 89 Euro ZZZ
Thats a big list for only 60,000k on it. It really needs pads and rotors? mine were still half left at 95,000
surprised that the shocks are gone, haven't changed mine yet.
All the rest is not a surprise. I pulled my engine and did the works as well except for the water pump, but I seem to be in there every year anyway.
What about the main bearings, mine were at the brass and just caught them in time.
To bad it wasn't a standard, it would be my dream
GLWTS
GLWTS
Archive Gatekeeper
WP0ZZZ92ZKS840960
C08 Japan (LHD)
M462 Sekuriflex windshield
I567 Windshield tinted, Upper part darker colored.
Too bad about the automatic, that's probably as light a stock S4 as exists, short of an SE or a CS....
C08 Japan (LHD)
