928 Forum 1978-1995
Sponsored by: 928 Specialists
1978 5 speed manual problem
Old May 3, 2013 | 12:38 AM
wilsonIII's Avatar
wilsonIII
Default 1978 5 speed manual problem
I just acquired a 1978 928 with a 5 speed manual gearbox.
The gearshift lever has no tension on it. The lever can fall from right to left untill it hits the side of the gearshift tunnel (the small springs inthe shifter housing are intact). However all gears (including reverse) can be selected but since basically no neutral gate, not really driveable.
(clutch seems to be fine)
I am wondering if the lockout spring in the gearbox could be the problem source?
Old May 3, 2013 | 02:06 AM
Optimator's Avatar
Optimator
Rear shift coupler perhaps? The plastic bushings crack, then fall out, rendering the shifter almost non-functional. Relatively easy to visually inspect.
Old May 3, 2013 | 02:13 AM
medipedicman's Avatar
medipedicman
The coupler is located above the torque tube.
File Type: jpg
File Type: jpg
Old May 3, 2013 | 12:52 PM
wilsonIII's Avatar
wilsonIII
Thank you very much! I will check that out this week end!! (obviously not something I would have thought of)
Old May 4, 2013 | 10:01 AM
Shark Attack's Avatar
Shark Attack
I doubt that's it. If all gears can be selected this wouldn't be the issue. Sounds internal to me.
Old May 4, 2013 | 10:18 AM
LT Texan's Avatar
LT Texan
If it flops over to R-1st, it is not the ball cup or the rear coupler IMO.
Does sound internal.
Not sure I understand what you mean by it doesn't have a neutral gate.
Old May 4, 2013 | 11:16 AM
SimonC's Avatar
SimonC
It could also be the front ball joint. I had similar symptoms with the floppy gear stick, but could engage gears for a while until it jumped right off. Its worth thinking about that as your problem (although I could find neutral). I cant remember if you can see it or not from the underside. I remember that I lashed some wire around the gear selector rod to hold it down on the ball joint until I got it repaired.
Old May 5, 2013 | 10:27 PM
wilsonIII's Avatar
wilsonIII
I do thank everyone - it would appear for the most part it is the rear coupler - has no bushings! (I have not checked the front ball joint yet)
Any cheap ideas on where I can obtain the bushings?
Again thanks everyone for your help!!
Old May 5, 2013 | 11:40 PM
Dave928S's Avatar
Dave928S
Here's a link to an old post of mine showing pics and a parts breakdown of the rear coupler .... https://rennlist.com/forums/9840872-post11.html
You can get new standard or delrin bushings for the rear coupler (and the front coupler bush) from Roger at 928'sRus ... I've used delrin for the rear and they're better than standard IMO.
Search 'rear coupler' and you'll find quite a few threads, including the one that has the above post.
Old May 6, 2013 | 01:25 PM
wilsonIII's Avatar
wilsonIII
Note: I did go back and reviewed postings on the transmission rear coupler and I also will be ordering the delrin bushing from 928'sRUs.
Thanks for the help, I am now waiting for the parts.
