Wheel fitting on a 82?
I tried searching for this topic, but no luck. I have been told that a turbo twist
8J x 18 ET50 will bolt right on the front without a problem. Will a 11J x 18 ET45fit on the back? If the 11J is too big, would it fit if you rolled the fender lip? What size tires would be recommended with these rims? I have 16 inch dials on it now with almost brand new Bridgestone Potenza 225/50VR16, anyone interested?
I think it should fit, but the offset in the front is too low, ET60 would be ideal.
Rears will be tight but with a little rolling I think they should fit.
Cheers
Cheers
