928 Forum 1978-1995
Sponsored by: 928 Specialists
Running problem with engine
Old Apr 30, 2013 | 03:54 PM
Per-Kristian's Avatar
Per-Kristian
3rd Gear
Default Running problem with engine
Hey. Has a 928 s, 1979 mod :-) It has been a while since it has been started. The problem is: it starts fine but only runs for about 10 seconds after initial boot, when I will start it again it only runs for about 5 seconds, then stops!!
I have cleaned the fuel system until the engine and force driven fuel pump, fuel filter replaced, but the same problem is still there, it will not run! Anyone have a tip on what could be wrong?? THANKS .....
Old Apr 30, 2013 | 04:21 PM
SteveG's Avatar
SteveG
I will take a shot: Fuel pump relay is cutting out. It would be nice to know for sure if fuel pressure is dropping off at 10 seconds. Or fuse 22.
Old Apr 30, 2013 | 04:51 PM
Per-Kristian
3rd Gear
I have replaced the relay, but the problem is still there!
Old Apr 30, 2013 | 04:59 PM
Lizard928's Avatar
Lizard928
It's starting and running on the cold start injector.
The CIS fuel distributor is not opening the injectors, or the injectors are plugged.
Old Apr 30, 2013 | 05:28 PM
Per-Kristian
3rd Gear
Can you please explain to me how / where CIS fuel distributor is located? How do I clean injectors? Thanks....
