F....... up TB/WP job
Hi all
I bought 1988 S4Auto last November.
PO gave me a lot of his bills what was done to the car.
One of them was WP/TB job().He did only 2000km after that repair and was moving to USA so i got the car for $7000.00
Car was in good shape,passed E test and safety but was making a bit of
whining noise .After reading a lot about WP failure consequences decided
to open it up and check.Here is what i find.
TB belt looks new
Water pump is not leaking
New tensioner pulley
Cam gears are a bit worn out
and the worst part,--> my harmonic balancer is rubbing against tensioner
pulley screw
Is it possible they put(pulley) up side dawn?
The big tick washer should be in front or behind pulley?
It does not let me upload pic hmmmmmmm
TB belt looks new
pulley screw
Team Owner
the order of parts that fit to the crank .
1. Thrust washer with the curved rim edge facing the engine
2. Timing belt drive gear
3. Thrust washer with the curved rim edge facing the front of the car.
Looks like this from a side view.
GOOD front thrust washer)GEAR(rear thrust washer
BAD front thrust washer(GEAR) rear thrust washer
NOTE these thrust washers act as belt guides so to keep the belt aligned, IF the washers are turned around they will grind the edges of the belt.
4. Crank damper in position so you can read the numbers while facing the engine..
5. A/C pulley
6. Front belt pulley
7. Thick washer with the counter bore facing the crank snout (the smooth side facing the bottom of the bolt head)
8. Crank bolt.
If the tensioner is hitting the rear of the damper then the tensioner bushings are bad.
you cant install the tensioner arm backwards as it wont fit the tensioner pin
5. A/C pulley
8. Crank bolt.
Hi Merlin
It looks right on crank,have both washers facing as you described.
On the other hand that tensioner pulley screw is sticking to far back.!!!!!
Belt looks straight .Can i send you pictures via e mail? it is not letting me upload them here
Thx
Thx
Under the Lift
pulley screw
pulley screw
Team Owner
check your RL e mail
If you become a member, you can do a lot of things you can't as a user.
Looks like you're local. If you want me to have a look, let me know.
Hi all
TB belt looks new
pulley screw
TB belt looks new
pulley screw
IF the washer that Bill identified is missing let us know......many have old OEM tensioners in the parts bin after installing the Porkensioner
Thx all
In my opinion washers on bolt #5 were backwords.I.m talking about bolt #5 and washer #4 that is on the other side of pulley.On my tensioner tick washer is on the outside .I believe washers #4 and #6 were flipped.They must not be the some thickness.
I.m in Aurora Ontario ,any locals can help ?
Thx again
Thx again
Team Owner
pictures of the offending washer,
This washer needs to be moved from the front of the stack to the back,
The bolt should be replaced ,
and damper should have a some paint sprayed on it to protect it from corrosion.
A new belt should also be fitted
Also measure the width of the belt as it appears that the belt teeth have also been worn down on the front edge,
though the thrust washer appears OK it may be wise to replace both of them to guarantee they are straight,
Look at the other parts of the belt run ,
I dont like the front edge of the belt teeth being worn to a step, something else is wrong.
I wonder if tone of the thrust washers could have been installed backwards to cause the belt teeth to be damaged
I'd be strongly consider replacing the water pump as well with one of the 2 known good replacements (talk to 928sRus), though maybe not the cause of the belt scalp. And dis/re-assembling the tensioner apparatus with new seals.
Might be best to redo the whole job at this point. Belt will need to be replaced anyway.
Mechanic did bad work. Now its time to rework all of it. Too risky not to on a 7K car. You already made the call, wisely, follow the logic thru.
Mech / PO might very well have utilized a rebuilt or ebay 99 dollar pump. Issue is not leakage, its migration of impeller into block where it performs undesirable machine work.
Team Owner
I agree with Chris a new WP and total inspection of the all the belt run parts are in order
Thx All
Thank you mr.Merlin for posting my pictures.
I.m going to give Roger a call and start all over.
Should i go with Porkensioner at this time?do you guys recommend it?
Salute
Salute
