Alternator connections
late 79 (80 model?) 928, 4.5 manual.
I'm replacing my alternator with a Bosch AL325X (thanks Roger!) and struggling to work out the connections. Been searching all over the place on loads of different forums but can't find the answer I need.
Long story short, it was someone else who took the old alternator off, and I no longer have it. So I don't know how the old one looked or was wired.
Anyway, I have 3 wires coming from the car
one of which has continuity to the starting post in the engine bay. I'll hold my hands up and admit I don't know much about alternators but I am reading up and trying to learn. The other 2 connectors would be - one live when ignition is on, and one to the back of the dash to go through the bulb, right?
Here's a pic of the alternator -
I'm thinking the top left connector with the big nut on it will go to the battery (positive of course), since the plastic part has a + on it :-) so the $64,000 question is where do the other 2 connectors go.
Could anyone shed some light on it for me?
Kev
The small ring goes on the small post.
There are only 2 connections really Porsche just happens to connect two together on the alternator stud, these are 2 red wires (that now look more brown due to heat and chemicals).
These are the B+ wires - one to the starter and one to the jump post.
The other is the 61 wire to the bulb & resistor in the pod the other side of the bulb/Rx is ignition (15) - it doesn't go to the alternator.
Alan
Thanks again,
Dave
PS
I see you say "the small ring goes to the small post" so I think I misunderstood. I would ask however, which post? And what does it mean that the other wire doesn't go to the alternator. Which wire does and which wire doesn't? Sorry to be dense.
Thanks,
Dave
On some German alternators you may also see (61) and (30) for D+ and B+ respectively.
On re-reading what I wrote it does seem a bit confusing...
Alan
I’m always in the background making snide remarks while sucking in technical offerings from the likes of you and others.
I don’t really have much 928 knowledge to share so hopefully I can occasionally help someone by merely rewording the wisdom of those that do.
Im trying to connect up my 1979 alternator. I have 3 connections on the alternator and 3 wires on the loom. One is easy since its smaller. The other two are more difficult.
I have plugged the brown/red wire into the B+ terminal and the green/black (maybe blue) into the D+ terminal... that leaves the other wire to go into the middle terminal.
Does anyone know if that is correct ?
Thanks in advance!
Todd.
